Extra Jabber licenses on a BE6K 25 user bundle
moin.sayed79
Hi Team,
Please advice what is the part number to add extra Jabber licenses on a BE6K 25 user bundle
Moin
6 Replies 6
Andrew Hickman
Can you be more specific about which Jabber features you need to use?
For voice features, you get desktop phone control with any UCM user license. If you want to use it as a soft client, you'll need an Enhanced user license as a minimum.
If you just need instant messaging, then order Jabber addon right to use licenses as required. This are available at no additional cost.
Please take a look at the Business Edition 6000 Ordering Guide for further details. http://www.cisco.com/web/partners/sell/technology/ipc/uc_tech_readiness.html
Andy
Hi Andy,
Thanks for the reply. My customer was confused and this is not what she wanted. She needs to add 5users to an existing 25user startup bundle.
What license part number should I propose?
Moin
Hi Moin,
If you choose the 25 User UCL starter pack, you are entitled to deploy 25 users with one device and a voicemail account each.
If you choose the UWL starter pack, then those first 25 users are allowed to use as many devices as there need and also get voicemail.
So it really depends on what devices / services those next 5 users require.
As an example, if you select the UCL starter pack and you want the next 5 to be exactly the same, purchase Qty 5
BE6K-UCL-ENH and Qty 5 BE6K-UCL-VM licenses under top level part R-CBE6K-K9.  Alternatively if you started with UWL licenses, order Qty 5 BE6K-UWL-BE.
Both of these options allow the use of Jabber - but see my initial comments on what exactly you want to use that client for.
If you haven't seen it already, I would strongly suggest you take a look at the Quick Pricing Tool - this takes a very straight forward approach to collecting end user collaboration requirements and converting this to an appropriate BE6000 bill of materials.
www.cisco.com/go/qpt
Andy
Hi Andy,
Below is their current infrastructure.
#Part NumberPart   Description Service DurationList PriceQuantityExtended List   Price
1.0CAB-ACAC Power Cord (North   America), C13, NEMA 5-15P, 2.1m -.001.00
2.0BE6K-START-UWL25BE 6000 - User   License Starter Bundle with 25 UWL Licenses -1,180.0011,180.00
3.0JAB9-DSK-UWLJabber for Desktop   9.x for CUWL Only -.0024.00
4.0R-CBE6K-K9Cisco Business   Edition 6000-Electronic SW Delivery-Top Level -.001.00
4.1UCM-9X-UWL-BEBE6K UCM 9.x CUWL BE   Users -.0025.00
4.1.1UCSS-U-6KUWLBE-3-1BE6K UCSS for CUWL-BE   User - 3 Years - 1 User 36.0082.60252,065.00
4.2UCM-90-ENH-UCLBE6K UCM 90 Enhanced   User Connect License -.002.00
4.2.1UCSS-U-6K-ENH-3-1BE6K - UCSS for   Enhanced User - 3 Years - 1 User 36.0042.48284.96
4.3UCM-9X-ESS-UCLBE6K UCM 9X Essential   User Connect License -.004.00
4.3.1UCSS-U-6K-ESS-3-1BE6K - UCSS for   Essential User - 3 Years - 1 User 36.008.26433.04
4.4BE6K-UCL-ENHCisco Business   Edition 6000 - Ehanced User Connect License -247.802495.60
4.5BE6K-UCL-ESSCisco Business   Edition 6000 - Essential User Connect License -47.204188.80
4.6BE6K-9X-PAKBE6K 9.X PAK (UCM,   Unty Cn, CUP) -.001.00
5.0BE6K-ST-BDL-K9=Cisco BE6000 UCS   C220M3 MD Srv,RST 9.x SW,Hyp,UPM,VCS -11,092.00111,092.00
5.1CAB-9K12A-NAPower Cord, 125VAC   13A NEMA 5-15 Plug, North America -.001.00
5.2BE6K-SW-9.XCisco Business   Edition 6000 - Software Version 9.X -.001.00
5.3CCX-90-CMBUNDLE-K9CCX 9.0 Promo Bundle   available only with NEW CUCM or BE6000 -.001.00
5.4CIT-PSU-BLKPPower Supply Blanking   Panel/Filler -.001.00
5.5CIT-SD-16G-C22016GB SD Card Module   for C220 servers -.001.00
5.6CTI-VCSC-BE6K-PAKConfig Only   E-Delivery VCS Control PAK PID -.001.00
5.7LIC-VCS-10+Video Comm Server 10   Add Non-traversal Network Calls -.001.00
5.8LIC-VCS-BASE-K9License Key - VCS   Encrypted Software Image -.001.00
5.9LIC-VCS-GWEnable GW Feature   (H323-SIP) -.001.00
5.10LIC-VCSE-5+Video Communication   Server - 5 Traversal Calls -.001.00
5.11PCP-BE6K-90-K9Cisco Prime   Collaboration Provisioning for BE6K 9.0 -.001.00
5.12R2XX-RAID10Enable RAID 10   Setting -.001.00
5.13UC-A03-D500GC3500GB  6Gb SATA    7.2K RPM SFF Hot Plug/Drive Sled Mounted -.004.00
5.14UC-CPU-E5-26092.4 GHz E5-2609/80W   4C/10MB Cache/DDR3 1066MHz -.002.00
5.15UC-MR-1X082RY-A8GB DDR3-1600-MHz   RDIMM/PC3-12800/Dual Rank/1.35v -.004.00
5.16UC-PSU-650W650W Power Supply   Unit For UCSC C220 Rack Server -.001.00
5.17UC-RAID-9266MegaRAID 9266-8i +   Battery Backup for C240 and C220 -.001.00
5.18VMW-VS5-HYP-K9Vmware vSphere -   Hypervisor 5.0 -.001.00
5.19VMW-VS5-SNSVmware vSphere   Hypervisor SnS 5.0 -.001.00
6.0UCSC-PSU-650W=650W power supply for   C-series rack servers -743.401743.40
7.0CAB-9K12A-NA=Power Cord, 125VAC   13A NEMA 5-15 Plug, North America -29.50129.50
8.0CUP9-ONPREM-OPTIncluded CUCM IM and   Presence for on-premise use -.001.00
9.0VOIP-IPH-UWLCisco Mobile Voice   Client for iPhone -.0024.00
10.0CISCO2901-V/K9Cisco 2901 UC Bundle,   PVDM3-16, UC License PAK -3,180.1013,180.10
10.1CAB-ACAC Power Cord (North   America), C13, NEMA 5-15P, 2.1m -.001.00
10.2PVDM3-6464-channel   high-density voice and video DSP module -3,776.0013,776.00
10.3VIC2-4FXOFour-port Voice   Interface Card - FXO (Universal) -1,038.4011,038.40
10.4VWIC3-1MFT-T1/E11-Port 3rd Gen   Multiflex Trunk Voice/WAN Int. Card - T1/E1 -1,687.4011,687.40
10.5PWR-2901-ACCisco 2901 AC Power   Supply -.001.00
10.6PI-MSE-PRMO-INSRTInsert, Packout -   PI-MSE -.001.00
10.7SL-29-IPB-K9IP Base License  for Cisco 2901-2951 -.001.00
10.8SL-29-UC-K9Unified   Communication  License  for Cisco 2901-2951 -.001.00
10.9S29UK9-15204MCisco 2901-2921 IOS   UNIVERSAL -.001.00
10.10HWIC-BLANKBlank faceplate for   HWIC slot on Cisco ISR -.002.00
10.11ISR-CCP-EXPCisco Config Pro   Express on Router Flash -.001.00
10.12MEM-2900-512MB-DEF512MB DRAM for Cisco   2901-2921 ISR (Default) -.001.00
10.13MEM-CF-256MB256MB Compact Flash   for Cisco 1900, 2900, 3900 ISR -.001.00
10.14PVDM3-1616-channel   high-density voice and video DSP module -.001.00
11.0WS-C2960S-24TS-SCatalyst 2960S 24   GigE, 2 x SFP LAN Lite -2,236.1012,236.10
12.0CAB-ACAC Power Cord (North   America), C13, NEMA 5-15P, 2.1m -.001.00
13.0CON-ESW-RCBE6KKESSENTIAL SW Cisco   Business Editi 12.00.003.00
14.0CON-ESW-UCM9XUBEESSENTIAL SW BE6K UCM   9.x CUWL BE 12.0024.78751,858.50
15.0CON-ESW-UCM90ENHESSENTIAL SW BE6K UCM   90 Enhanced 12.0015.34692.04
16.0CON-ESW-UCM9XESSESSENTIAL SW BE6K UCM   9X Essentia 12.002.361228.32
17.0CON-SNTP-BE6KSTBDSMARTNET 24X7X4 Cisco   Business Edition 6000 UCS Srv 9.0 12.00450.7631,352.28
18.0CON-SNTP-2901VSMARTNET 24X7X4 Cisco   2901 Voice Bun 12.00575.8431,727.52
19.0CON-SNTP-2960S2SSSMARTNET 24X7X4 Cat   2960S 24 GigE,2 x SFP LAN Lite 12.00214.763644.28
20.0C2901-CME-SRST/K92901 UC Bundle w/   PVDM3-16,FL-CME-SRST-25, UC License PAK -3,770.1013,770.10
20.1CAB-ACAC Power Cord (North   America), C13, NEMA 5-15P, 2.1m -.001.00
20.2VIC2-4FXOFour-port Voice   Interface Card - FXO (Universal) -1,038.4011,038.40
20.3PWR-2901-ACCisco 2901 AC Power   Supply -.001.00
20.4FL-CME-SRST-25Communication Manager   Express or SRST - 25 seat license -.001.00
20.5PI-MSE-PRMO-INSRTInsert, Packout -   PI-MSE -.001.00
20.6SL-29-IPB-K9IP Base License  for Cisco 2901-2951 -.001.00
20.7SL-29-UC-K9Unified   Communication  License  for Cisco 2901-2951 -.001.00
20.8S29UK9-15204MCisco 2901-2921 IOS   UNIVERSAL -.001.00
20.9FL-CMECisco Communications   Manager Express License -.001.00
20.10HWIC-BLANKBlank faceplate for   HWIC slot on Cisco ISR -.003.00
20.11ISR-CCP-EXPCisco Config Pro   Express on Router Flash -.001.00
20.12MEM-2900-512MB-DEF512MB DRAM for Cisco   2901-2921 ISR (Default) -.001.00
20.13MEM-CF-256MB256MB Compact Flash   for Cisco 1900, 2900, 3900 ISR -.001.00
20.14PVDM3-1616-channel   high-density voice and video DSP module -.001.00
21.0ATA187-I1-A=Cisco ATA 187 with   configurable impedance -354.001354.00
21.1ATA187PWRCORD-NAATA187 power supply   cable for North America -.001.00
22.0CP-7937G=Cisco UC Conference   Station 7937 Global -1,646.1011,646.10
23.0CP-7937-MIC-KIT=Microphone Kit (7   ft)  for 7937 -413.001413.00
24.0WS-C2960S-24PS-LCatalyst 2960S 24   GigE PoE 370W, 4 x SFP LAN Base -3,770.1013,770.10
25.0CAB-ACAC Power Cord (North   America), C13, NEMA 5-15P, 2.1m -.001.00
26.0CON-SNTP-2901CMSTSMARTNET 24X7X4 2901   Voice Bundle w/ UC License PAK 12.00575.8431,727.52
27.0CON-SNTP-ATA187I1SMARTNET 24X7X4 Cisco   ATA 187 with 600 ohm impedance 12.0044.843134.52
28.0CON-SNTP-2960S2PSSMARTNET 24X7X4   Catalyst 2960S Stack 12.00362.2631,086.78
29.0C2911-CME-SRST/K92911 UC Bundle   w/PVDM3-16,FL-CME-SRST-25, UC License PAK -4,596.1014,596.10
29.1CAB-ACAC Power Cord (North   America), C13, NEMA 5-15P, 2.1m -.001.00
29.2VIC2-4FXOFour-port Voice   Interface Card - FXO (Universal) -1,038.4011,038.40
29.3FL-SRSTCisco Survivable   Remote Site Telephony License -.001.00
29.4FL-CME-SRST-25Communication Manager   Express or SRST - 25 seat license -.001.00
29.5PWR-2911-ACCisco 2911 AC Power   Supply -.001.00
29.6PI-MSE-PRMO-INSRTInsert, Packout -   PI-MSE -.001.00
29.7SL-29-IPB-K9IP Base License  for Cisco 2901-2951 -.001.00
29.8SL-29-UC-K9Unified   Communication  License  for Cisco 2901-2951 -.001.00
29.9S29UK9-15204MCisco 2901-2921 IOS   UNIVERSAL -.001.00
29.10HWIC-BLANKBlank faceplate for   HWIC slot on Cisco ISR -.003.00
29.11ISR-CCP-EXPCisco Config Pro   Express on Router Flash -.001.00
29.12MEM-2900-512MB-DEF512MB DRAM for Cisco   2901-2921 ISR (Default) -.001.00
29.13MEM-CF-256MB256MB Compact Flash   for Cisco 1900, 2900, 3900 ISR -.001.00
29.14PVDM3-1616-channel   high-density voice and video DSP module -.001.00
29.15SM-S-BLANKRemovable faceplate   for SM slot on Cisco 2900,3900,4400 ISR -.001.00
30.0ATA187-I1-A=Cisco ATA 187 with   configurable impedance -354.001354.00
30.1ATA187PWRCORD-NAATA187 power supply   cable for North America -.001.00
31.0CP-7937G=Cisco UC Conference   Station 7937 Global -1,646.1011,646.10
32.0CP-7937-MIC-KIT=Microphone Kit (7   ft)  for 7937 -413.001413.00
33.0CON-SNTP-2911CMSTSMARTNET 24X7X4 2911   Voice Bundle w/ UC License PAK 12.00830.7232,492.16
34.0CON-SNTP-ATA187I1SMARTNET 24X7X4 Cisco   ATA 187 with 600 ohm impedance 12.0044.843134.52
35.0CP-8941-K9=Cisco Unified Phone   8941, Phantom Grey, Standard Handset -501.501501.50
36.0CP-8945-K9=Cisco Unified Phone   8945, Phantom Grey, Standard Handset -619.501619.50
37.0CP-7942G=Cisco UC Phone 7942,   spare -466.101466.10
38.0CP-7945G=Cisco UC Phone 7945,   Gig Ethernet, Color, spare -578.201578.20
39.0CP-8941-K9=Cisco Unified Phone   8941, Phantom Grey, Standard Handset -501.5084,012.00
40.0CP-8945-K9=Cisco Unified Phone   8945, Phantom Grey, Standard Handset -619.5084,956.00
41.0CP-7942G=Cisco UC Phone 7942,   spare -466.1083,728.80
42.0CP-7945G=Cisco UC Phone 7945,   Gig Ethernet, Color, spare -578.2084,625.60
Sorry to persist, but I still need to understand what exactly the customer wants to use the additional Jabber clients for - as licensing will vary depending on the requirement.
I assume from your list of products above that some of the end users will be assigned multiple handsets?  (I see 38 devices to 27 licenses).
When ordering, you could have included additional Jabber client right to use licenses if required.
Andy
Hi Andrew,
Thanks for trying to help me. I will pass this information to my customer.
Moin
