fax over sip codec problem
gdamjanovic
hi all,
i recently deployed UC560 on custormer site. for short period we used BRI for telephony. Now we are using sip trunk from local provider. Voice calls work fine but we are having trouble with fax. Provider said that we are using wrong codec(g729) on our side. In CCA we configured fxs port for fax. on sip trunk we configured all options that provider gave as. (codec G711..). When troubleshooting in CCA I noticed in PCM capture that when fax is ringing codec is G711, but when fax ansewers than codec shown is G729r8. Customer uses did translation and have sesicated number for fax. My question is Is there way to force (hardcode) UC to use only G711 codec for incoming and outgoing fax calls?
Thanx all in advance for all replies.
BR,
Goran
When a call doesn't match an existing dial-peer, the cisco uses an hidden dial-peer 0 that uses g729 codec.
How many dial-peer are configured?
Can you use the command "sh voice call status " during a call?
In this way we can see what dial-peer is used.
Regards.
8 Replies 8
You can do this in different ways.
- You can configure the fax-upspeeding adding these commands in your dial-peer:
      modem passthrough nse codec g711alaw
      fax rate disable
      fax protocol pass-through g711alaw
In this way, when UC DSP recognizes the FAX CED tone changes the codec to G.711.
- You can also force G.711 as only available codec replacing the "voice-class codec" with "codec g711a" in dial-peer.
- You can try to define specific dial-peers (incoming and outgoing) for fax number. Something like this:
dial-peer voice 15 voip
description FAX out
answer-address "YOUR FAX NUMBER"
session protocol sipv2
session target dns:"YOUR ITSP"
session transport udp
dtmf-relay rtp-nte
codec g711alaw
fax rate disable
no vad
dial-peer voice 16 voip
description FAX in
incoming called-number "YOUR FAX NUMBER"
dtmf-relay rtp-nte
codec g711alaw
fax rate disable
no vad
Regards.
Thanx for replay,
I tried everything but no luck I done some furder debuging and i think that provider is fooling us aronud. I think that its side is offering G729 codec and our side reply-s. Can you tell me how to now witch messages is from provider and whitch are reply
Add the output of "debug ccsip messages".
Regards.
Here is some from the start of the call.
006349: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:013436334@172.16.61.74:5060;user=phone SIP/2.0
Allow: UPDATE,REFER,INVITE,ACK,OPTIONS,REGISTER,SUBSCRIBE,MESSAGE,NOTIFY,BYE,CAN
CEL,PRACK
Call-ID: 26762-TA-a524bec4-3ef4ac612@sip-priv.amis.hr
Contact: <172.16.1.20:5060>
Content-Type: application/sdp
CSeq: 621891236 INVITE
From: "016637806" <>016637806@sip-priv.amis.hr;user=phone>;tag=26762-WF-a524b
ec5-7368e5290
Max-Forwards: 30
Min-SE: 90
Session-Expires: 600
Supported: timer,100rel
To: <013436334>
User-Agent: Amis/HR (SBC)
Via: SIP/2.0/UDP 172.16.1.20:5060;branch=z9hG4bK-2F0F-22B2254
Content-Length: 347
v=0
o=cp10 134069476827 134069476827 IN IP4 172.16.2.35
s=SIP Call
c=IN IP4 172.16.2.35
t=0 0
m=audio 31792 RTP/AVP 8 0 18 125 101
b=AS:82
a=rtpmap:8 PCMA/8000/1
a=rtpmap:0 PCMU/8000/1
a=rtpmap:18 G729/8000/1
a=fmtp:18 annexb=no
a=rtpmap:125 CLEARMODE/8000/1
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=ptime:20
a=sendrecv
006350: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 422 Session Timer too small
ec5-7368e5290
To: <013436334>;tag=34DECE0-1D46
Date: Tue, 26 Jun 2012 07:11:37 GMT
Allow-Events: telephone-event
Min-SE:  1800
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
006351: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:013436334@172.16.61.74:5060;user=phone SIP/2.0
CSeq: 621891236 ACK
ec5-7368e5290
Max-Forwards: 30
Content-Length: 0
006352: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CEL,PRACK
CSeq: 621891254 INVITE
ec5-7368e5290
Max-Forwards: 29
Min-SE: 1800
Session-Expires: 1800
To: <013436334>
Via: SIP/2.0/UDP 172.16.1.20:5060;branch=z9hG4bK-737B-22B2258
Content-Length: 347
v=0
o=cp10 134069476829 134069476829 IN IP4 172.16.2.35
s=SIP Call
t=0 0
m=audio 37208 RTP/AVP 8 0 18 125 101
b=AS:82
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=ptime:20
a=sendrecv
006353: //6208/0100004183B1/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
ec5-7368e5290
To: <013436334>
Content-Length: 0
006354: //6208/0100004183B1/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 183 Session Progress
ec5-7368e5290
To: <013436334>;tag=34DED10-B86
Require: 100rel
RSeq: 776
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIF
Y, INFO, REGISTER
Contact: <013436334>
Supported: sdp-anat
Content-Disposition: session;handling=required
Content-Length: 191
v=0
o=CiscoSystemsSIP-GW-UserAgent 5168 3647 IN IP4 172.16.61.74
s=SIP Call
t=0 0
m=audio 16684 RTP/AVP 18
c=IN IP4 172.16.61.74
a=fmtp:18 annexb=no
a=ptime:20
006355: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
PRACK sip:013436334@172.16.61.74:5060 SIP/2.0
CSeq: 621891255 PRACK
ec5-7368e5290
Max-Forwards: 29
RAck: 776 621891254 INVITE
Via: SIP/2.0/UDP 172.16.1.20:5060;branch=z9hG4bK-5FB-22B2259
Content-Length: 0
006356: //6208/0100004183B1/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
ec5-7368e5290
Content-Length: 0
006357: //6208/0100004183B1/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
ec5-7368e5290
Y, INFO, REGISTER
Supported: replaces
Supported: sdp-anat
Require: timer
Session-Expires:  1800;refresher=uac
Supported: timer
Content-Length: 191
v=0
s=SIP Call
t=0 0
a=fmtp:18 annexb=no
a=ptime:20
006358: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 621891254 ACK
ec5-7368e5290
Max-Forwards: 29
Via: SIP/2.0/UDP 172.16.1.20:5060;branch=z9hG4bK-75EA-22B229D
Content-Length: 0
006359: Jun 26 09:11:44.696: %SEC-6-IPACCESSLOGP: list 107 denied tcp 188.129.18
5.218(9635) -> 188.129.6.126(445), 1 packet
BR
This is the call flow:
- incoming INVITE from User-Agent: Amis/HR (SBC) with these codecs
a=fmtp:18 annexb=no
and option Min-SE: 90
- outgoing response from your cisco
422 Session Timer too small - Min-SE:  1800
- incoming ReINVITE form User-Agent: Amis/HR (SBC) with these codecs
a=fmtp:18 annexb=no
but new Min-SE: 1800
- outgoing final 200 OK response from your cisco with G729
a=fmtp:18 annexb=no
Your provider supports G711. You can add in your configuration using voice-class codec and right priority.
Regards.
thank you very mutch, but I am realy stuck here in voice class codec i have only g711 i dond know wrom were uc pulls g729 to offer.
Regards.
Thanx again very mutch for all your help.
Problem was in dial-peers. I managed to locate it by using command that you sugdested. Then I hardcoded g711alaw codec in configuration and matched configuration for incoming and outgoing dial-peer.
Best regards,
Goran
