Fax to email mailbox filling up
jyoopro4ia
We have few fax to email numbers setup on our UC540.  Problem we're having is that, no one actually monitors the actual voice mailboxes so when they become full fax to email stops working.
Is there a way to avoid this in the future - possibly automated?
Thanks.
j
6 Replies 6
dliao
AFAIK, there is no plan for auto delete message feature.
-David
David,
Thanks for the response.  What is the best way to manage a fax to email mailbox?  do all fax items that get sent via email also take up space in the mailbox?  does this mailbox need to be cleared manually periodically?
j
Mario Garcia
Level 3
Level 3
There is a way around this but I requires CLI. You would use the same TCL script but actually have the script deliver to an email address and not a CUE mailbox. When I get back to my PC I will post the a sample config.
An smtp relay will be needed for this to work properly.
-Mario
Never made it to a PC but here is a sample config
FAX TO EMAIL (PRI using DID)
UPLOAD THE FOLLOWING FILE TO FLASH
app_faxmail_onramp.2.0.1.3.tcl
ENTER THE FOLLOWING CONFIGURATION INTO CME
fax interface-type fax-mail
mta send server (SMTP RELAY SERVER) port 25 <-- Relay Server and port #
mta send subject Fax from Cisco System <--Message to display in subject line
mta send with-subject both
mta send mail-from hostname domain.com <-- from domain
mta send mail-from username fax<-- username name appears in from field
application
service onramp flash:app_faxmail_onramp.2.0.1.3.tcl
***CREATE TRANSLATION RULES AND PROFILE IF NEEDED
voice translation-rule 12
rule 1 /1234/ /1234/
voice translation-profile FAX_DIDs
translate called 12
***CREATE DIAL-PEER(S) FOR INCOMING CALL
dial-peer voice 2100 pots
description ""Incoming FAX DID"" <-- give dial-peer a description
service onramp
translation-profile incoming FAX_DIDs <-- apply profile name
incoming called-number 1234 <--enter the incoming digits
direct-inward-dial
port 0/2/0:23 <-- port that calls are coming in on
***CREATE MMOIP DIAL-PEER(S) FOR FAXES (one dial-peer per DID)
dial-peer voice 2500 mmoip
service fax_on_vfc_onramp_app out-bound
destination-pattern 1234 <-- enter the digits that are being sent to pbx
information-type fax
session target mailto:user@domain.com
Hope this helps
-Mario
Thanks Mario.
Fax to email was originally configured via CCA and I would like to keep it that way.  Is it correct to assume this is not an option when sticking only to CCA?
John
This is not a CCA supported item. If you turn off the fax to email in CCA and then setup via CLI, CCA will not break the config.
I have sent this setup to the CCA team to add as an option for Fax to Email setup.
