12-02-2009 06:51 AM - edited 03-21-2019 01:51 AM
I have been using the fax to voicemail feature for several customers, and they, as well as I, love it. The only issue I have is that the fax "mailbox" fills up. Unless I manually go into the mailbox and delete them. I have set the expiration to 3 days and they expire, but don't delete. Is there a way I can automate them deleting?
thanks,
12-02-2009 10:26 PM
It would be great if you could log into the web gui and just delete voice mails and faxes by clicking on a check box, how life would be much simpler and easier for us to create an admin account for clients and let them do that themselves..
Unless it is there and i have just missed it tottaly (I have a tendancy of doing things like that).
Cheers,
David.
12-04-2009 11:18 AM
Users or members of the group must delete CUE messages manually, so there is no automated way to do this.
Marcos
12-04-2009 11:30 AM
Thanks. It was one of those, if I ask maybe someone has a "workaround". Would be nice to have fax to e-mail configurable and maintainable via CCA.
12-04-2009 11:33 AM
You could implement IMAP and manipulate faxes from your outlook inbox. T.337 support in CCA is roadmapped, but not committed.
Marcos
