Hi there,I'm trying to have our UC500 function as the SIP endpoint for our local SIP provider (www.xs4all.nl)What I know is: Username Password SIP Server: sip.xs4all.nl Proxy: sip.xs4all.nl Proxy port: 5060 Expire time: 3600Codecs: G.711a G.7...
Hallo,i have a spa9000 and the gateway spa400, telephone provider is cable germany (Kabel Deutschland).Nearly every second or third phone call ends after 5 minutes. One telefon shows the ip code 701, which means that the the person which i have call ...
I have the ESW 540 under the UC520 and i was wondering if i could view all the devices under the switch in the CCA 2.0.1 Topology View. How can i achieve this, if possible?
I just bought an ATA 186 to connect my fax machine to the network. The manual says that the ATA is suppose to register like a phone to the CME, but when I plug that ATA to the network, CME doesn't see it and it's getting an IP address like a regular ...
We finally setup our UC520 system and have it running at work. We have an incoming PSTN line and a few incoming voip lines. Both go to the same Auto Attendant except for one DID. Tonight I noticed that after business hours, incoming voip calls wou...
Hi All,We have a UC520 with the latest firmware (early adopter pack).I have the region set to New Zealand. However, caller id does not seem to be working on any phones no matter the number. Is there something that needs to be changed?
Hi,I'm wondering if there's any parameter's that I can change on the SPA400 regarding PSTN connectivity. I have one customer who is experiencing that the calls are beeing dropped from time to time. This is a installation in Norway if that should matt...
When our customer uses their EditDial softkey to return a missed or received call, the cursor put them at the end of the 10 digit number string ? Most handsets have the cursor at the start of the digits so they can simply press 9 and call from there...
This is a very strange issue that just started monday morning (post DST change).Here is the call flow so you can understand the problem:PSTN --> AA 270 --> option 1 --> BACD Queue 1 EXT 790 --> if no one logged in or no answer after 120 seconds --> ...
Hi all,I have a hunt group that operates during the day. During the night, when night service is active, I'd like to forward all calls going to to the hunt group straight to the GDM for that hunt group, instead of ringing around the loop.Is this poss...
Hi everybody,Beginning, excuse me for my bad english. I'm French!So, I would like t know, how can I upload personnal tones over the SPA901 ?Witch format is it ?Thank you in advance for your reply!
Hi,I have deployed 10 IP Speakers for paging purposes on UC520, I have managed to call each one to page, I tried to create a Blast group and add the SIP extension to it but it didn't blas the speaker at ones, is there any way we can call all sip exte...
