06-19-2013 06:04 PM - edited 03-21-2019 10:04 AM
I'm using the SPA3102 to forward calls from PSTN toward Voip network. Is working very well with a local Voip Provider called Vono (www.vono.net.br), i think because this provider is one that has outbound proxy. However, I want to use SPA3102 forwardin PSTN calls with other providers like Freevoipdeal, VoipWise, VoipRaider etc. .. These providers have no outbound proxy. How can I get around this? According to the link below, you need to schedule an outbound proxy. What to do?
http://www.cisco.com/en/US/products/ps10024/products_qanda_item09186a0080a359ae.shtml#q
For example, the provider voip freevoipdeal guides that leave the field blank Outbound Proxi as below.
https://www.freevoipdeal.com/sip
Solved! Go to Solution.
06-20-2013 09:45 AM
You can leave the Outbound Proxy field blank. You do not have to have an entry in this field for the SPA3012 to work correctly.
06-20-2013 09:45 AM
