France Telecom configuration
Marc Montouchet
Hi there,
I'm new on this forum and also new on Cisco community.
Just 18 years of engeneering in computers, software and networks...
We're looking for a standard configuration of an UC540 / Bri connected to two France Telecom/T0.
All the configuration of the UC540 has been done and work perfectly on our Msft Network except the most important thing the PSTN Trunk.
We've 2 T0 with 10 SDA (DID) and would like to test Cisco products on such configuration.
Can somebody help us with this configuration, may be with a sample standard one ?
Thanks in advance
Marc
8 Replies 8
gondange1
you must use this configuration for FT :
interface BRI0/1/0
no ip address
isdn switch-type basic-net3
isdn point-to-point-setup
isdn incoming-voice voice
isdn sending-complete
trunk-group ALL_BRI 64
interface BRI0/1/1
no ip address
For DIDs, only the four last digits of the called number are transfered, so you must add transfer rules like this :
1234 -> 201  if the called number is 01 XX YY 12 34 for instance.
This can be done in CCA or by simple translation rules like this :
voice translation-rule 9
rule 1 /1234/ /201/
Stephane
Hello
Thanks a lot for your answer.
I'm on travel this week so I'll try that on friday.
Again thanks
Marc
Hi Stephane,
I did as you suggested and outgoing calls seem to work.
It's impossible to get incoming calls and every calls get a busy tonality from the outside...
Any idea ?
On our old system all DIDs were wtih 6 digits 68xxxx or 77xxxx is that right ?
Thanks for your answer
Marc
Non les DID ont juste 4 chiffres avec le numeris FT.
Il faut utiliser les 4 derniers chiffres du numéro pour router les appels dans l'UC500.
Bonjour,
En fait après avoir fait un "debug isdn", j'ai pu router mes appels à partir des ... 9 chiffres ... transmis par FT pourquoi 9, je ne sais...
Toujours est il que depuis que j'ai recréé mes règles à partir de cette constatation, cela fonctionne fort bien.
En tout cas merci de votre réponse
Marc
In fact after a "debug isdn", I could create the right rules based on 9 digits numbers trasmitted by FT why 9, I don't know
Then as I created my rules on this obesvation, it seems to work pretty well.
Thanks again for your answer
Marc
Bonjour Marc,
merci de venir à mon aide, peux tu me dire comment voir sur mon debug isdn, le nombre de digit en sortie.
Cordialement, Fabien
I'm planning for a CUCM site in France and need some configuration Help
we have 3 sites:
SiteA : 5 T0 lines
SiteB : 3 T0 lines
SiteC: 1 T2
i believe T2 is PRI, can you please share some working configuration for these 2 ISDN types
appreciate your help
Shameer
Sorry I was on holidays and couldn't answer your question.
Did you go further on that problem ?
Marc
