FXS will not dial out on SIP
obrien.cathal
I have installed a UC320W about a year or so ago. I have found that when anyone tries to dial out from the FXS through a SIP trunk they only get an engaged/busy tone. They can however dial out over the FXO line.
I am not sure if it is something I have set incorrectly but I have reviewed the settings numerous times and I cannot find a reason for it.
I would appreciate any help.
Cathal
wenyang
Level 4
Level 4
Hi Cathal,
Please contact the Small Business Support Center at the phone number listed (Please pick the appropriate phone number in your region) in the link attached? One of our engineers should be able to assist you with this issue.
http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Best regards,
Wendy Yang
madcarpe
Hello Cathal
Have you tried disabling and enabling the port again?
Here's a simple article on how to do that.
Enable or Disable FXS ports on UC320W
Hope this helps,
Madison Carpenter
Hi Madison,
Thanks for the advice. I will try this out and get back to you.
Cathal
