Gap Sip session on SPA8800
grishanov
Good afternoon, ladies and gentlemen.
I have configured two SPA8800 forwarding to 4 telephone lines, but when you call onone line to the FSO then after 60 seconds if no one is not picked up the precipice is SIPsession but sirens are calling from. Below is the logs of two SPA8800. Please help mesolve my problem.
With respect Andrew Grishanov
If I've correctly understood your request, your goal is to get a continuosly ring back tone instead of a disconnect tone after 60 seconds.
Check your Ring Back Tone configuration under Regional parameter menu of the FXS SPA8800.
This is my config: 425@-19;300(1/4/1)
300 is the timer of ring back tone. After 300 seconds the call is rejected.
Check your configuration. I think that you have a value of 60 seconds. If you want set infinit seconds you must use *.
infinit ring back tone: 425@-19;*(1/4/1)
Regards.
