08-24-2010 07:06 PM - edited 03-21-2019 02:55 AM
All,
I am having an issue with my dtmf not recognizing when a number is pressed on a phone. We have the ability to transfer phone calls to our operator if the recipient presses 1. However, when the recipient presses 1 the call is not transferred and eventually the call is dropped. I have turned on debugging for voip ccapi inout ; ccsip messages ; and voip ftp session named-event. I have attached the debug logs. Any help would be greatly appreciated.
UC520#
329272: *Aug 25 01:24:24.418: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:915558091234@192.168.0.2:5060 SIP/2.0
From: MyTest<sip:5551234567@127.0.0.1>;tag=b4473b8-0-13c4-50022-699f9-6e1c0fd3-699f9
To: <sip:915558091234@192.168.0.2>
Call-ID: 2798949081-0b4d6028-0b457e48-00000145@192.168.0.122
CSeq: 1 INVITE
Via: SIP/2.0/UDP 192.168.0.122:5060;branch=z9hG4bK-699f9-19c975c9-bd6d60
x-sid: d42ac1ec1a30ee8f0eb22f194f92a4ad
x-voxeo-aom: true
Max-Forwards: 70
User-Agent: VCS9.0.41716.0
Contact: <sip:5551234567@192.168.0.122:5060>
Content-Type: application/sdp
Content-Length: 282
v=0
o=- 432590925948 432590925948 IN IP4 127.0.0.1
s=voxeo
c=IN IP4 192.168.0.122
t=0 0
m=audio 10002 RTP/AVP 0 8 3 112 101
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:3 GSM/8000
a=rtpmap:112 L16/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=ptime:20
329273: *Aug 25 01:24:24.422: //47958/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
Call Entry Is Not Found
329274: *Aug 25 01:24:24.422: //-1/546501659166/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=5551234567
----- ccCallInfo IE subfields -----
cisco-ani=5551234567
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=ABCD915558091234
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-lastrdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
329275: *Aug 25 01:24:24.426: //-1/546501659166/CCAPI/cc_api_call_setup_ind_common:
Interface=0x85FBBD18, Call Info(
Calling Number=5551234567,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=ABCD915558091234(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=1003, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=47958
329276: *Aug 25 01:24:24.426: //-1/546501659166/CCAPI/ccCheckClipClir:
In: Calling Number=5551234567(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
329277: *Aug 25 01:24:24.426: //-1/546501659166/CCAPI/ccCheckClipClir:
Out: Calling Number=5551234567(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
329278: *Aug 25 01:24:24.426: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
329279: *Aug 25 01:24:24.426: :cc_get_feature_vsa malloc success
329280: *Aug 25 01:24:24.426: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
329281: *Aug 25 01:24:24.426: cc_get_feature_vsa count is 3
329282: *Aug 25 01:24:24.426: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
329283: *Aug 25 01:24:24.426: :FEATURE_VSA attributes are: feature_name:0,feature_time:2297170352,feature_id:54256
329284: *Aug 25 01:24:24.426: //47958/546501659166/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=5551234567(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=ABCD915558091234(TON=Unknown, NPI=Unknown))
329285: *Aug 25 01:24:24.426: //-1/xxxxxxxxxxxx/CCAPI/cc_build_feature_vsa:
329286: *Aug 25 01:24:24.426: :Inside cc_build_feature_vsa
329287: *Aug 25 01:24:24.426: //-1/xxxxxxxxxxxx/CCAPI/cc_build_feature_vsa:
329288: *Aug 25 01:24:24.426: feature call basic
329289: *Aug 25 01:24:24.426: //-1/xxxxxxxxxxxx/CCAPI/cc_build_feature_vsa:
329290: *Aug 25 01:24:24.426: cc_build_feature_vsa attr is fn:TWC,ft:08/24/2010
20:24:24.426,cgn:5551234567,cdn:ABCD915558091234,frs:0,fid:54256,fcid:54650165AF1E11DF91668E74D60711A1,legID:BB56
329291: *Aug 25 01:24:24.430: //47958/546501659166/CCAPI/cc_process_call_setup_ind:
Event=0x8675A2A0
329292: *Aug 25 01:24:24.430: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number ABCD915558091234
329293: *Aug 25 01:24:24.430: //47958/546501659166/CCAPI/ccCallSetContext:
Context=0x88EF6FAC
329294: *Aug 25 01:24:24.430: //47958/546501659166/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 47958 with tag 1003 to app "_ManagedAppProcess_Default"
329295: *Aug 25 01:24:24.430: //47958/546501659166/CCAPI/ccCallProceeding:
329296: *Aug 25 01:24:24.434: //47958/546501659166/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=1027, Params=0x88EEB1AC, Progress Indication=NULL(0)
329297: *Aug 25 01:24:24.434: //47958/546501659166/CCAPI/ccCheckClipClir:
329298: *Aug 25 01:24:24.434: //47958/546501659166/CCAPI/ccCheckClipClir:
329299: *Aug 25 01:24:24.434: //47958/546501659166/CCAPI/ccCallSetupRequest:
Destination Pattern=[7,9]1[2-9]..[2-9]......, Called Number=1XXXXXXXXXX, Digit Strip=FALSE
329300: *Aug 25 01:24:24.434: //47958/546501659166/CCAPI/ccCallSetupRequest:
Called Number=1XXXXXXXXXX(TON=Unknown, NPI=Unknown),
Redirect Number=, Display Info=MyTest
Account Number=5551234567, Final Destination Flag=TRUE,
Guid=54650165-AF1E-11DF-9166-8E74D60711A1, Outgoing Dial-peer=1027
329301: *Aug 25 01:24:24.434: //47958/546501659166/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=1XXXXXXXXXX
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-lastrdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
329302: *Aug 25 01:24:24.434: //47958/546501659166/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x85FBBD18, Interface Type=3, Destination=, Mode=0x0,
Call Params(Calling Number=5551234567,(Calling Name=MyTest)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=1XXXXXXXXXX(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=1027, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
329303: *Aug 25 01:24:24.438: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
329304: *Aug 25 01:24:24.438: :cc_get_feature_vsa malloc success
329305: *Aug 25 01:24:24.438: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
329306: *Aug 25 01:24:24.438: cc_get_feature_vsa count is 4
329307: *Aug 25 01:24:24.438: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
329308: *Aug 25 01:24:24.438: :FEATURE_VSA attributes are: feature_name:0,feature_time:2297175056,feature_id:54257
329309: *Aug 25 01:24:24.438: //47959/546501659166/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
329310: *Aug 25 01:24:24.438: //47959/546501659166/CCAPI/ccCallSetContext:
Context=0x88EEB15C
329311: *Aug 25 01:24:24.438: //47958/546501659166/CCAPI/ccSaveDialpeerTag:
329312: *Aug 25 01:24:24.438: //47959/546501659166/CCAPI/cc_api_call_proceeding:
Interface=0x85FBBD18, Progress Indication=NULL(0)
329313: *Aug 25 01:24:24.442: //-1/xxxxxxxxxxxx/CCAPI/cc_build_feature_vsa:
329314: *Aug 25 01:24:24.442: :Inside cc_build_feature_vsa
329315: *Aug 25 01:24:24.442: //-1/xxxxxxxxxxxx/CCAPI/cc_build_feature_vsa:
329316: *Aug 25 01:24:24.442: feature call basic
329317: *Aug 25 01:24:24.442: //-1/xxxxxxxxxxxx/CCAPI/cc_build_feature_vsa:
329318: *Aug 25 01:24:24.442: cc_build_feature_vsa attr is fn:TWC,ft:08/24/2010
20:24:24.438,cgn:5551234567,cdn:1XXXXXXXXXX,frs:0,fid:54257,fcid:54650165AF1E11DF91668E74D60711A1,legID:BB57
329319: *Aug 25 01:24:24.446: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Wed, 25 Aug 2010 01:24:24 GMT
Allow-Events: telephone-event
Content-Length: 0
CSeq: 1 INVITE
Server: Cisco-SIPGateway/IOS-12.x
329320: *Aug 25 01:24:24.450: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:1XXXXXXXXXX@sipconnect.dal0.cbeyond.net:5060 SIP/2.0
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
From: "MyTest" <sip:5551234567@sipconnect.dal0.cbeyond.net>;tag=5D0E3984-1CCB
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 1415905637-2937983455-2439417460-3590787489
Timestamp: 1282699464
Content-Length: 244
User-Agent: Cisco-SIPGateway/IOS-12.x
To: <sip:1XXXXXXXXXX@sipconnect.dal0.cbeyond.net>
Contact: <sip:5551234567@192.168.0.2:5060>
Expires: 180
Content-Disposition: session;handling=required
Call-ID: 54680EC6-AF1E11DF-916C8E74-D60711A1@sipconnect.dal0.cbeyond.net
Via: SIP/2.0/UDP 192.168.0.2:5060;branch=z9hG4bK8D36A1F
CSeq: 101 INVITE
Max-Forwards: 69
v=0
o=CiscoSystemsSIP-GW-UserAgent 6174 8806 IN IP4 192.168.0.2
s=SIP Call
c=IN IP4 192.168.0.2
t=0 0
m=audio 16596 RTP/AVP 0 101
a=fmtp:101 0-15
a=ptime:20
329321: *Aug 25 01:24:24.502: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 401 Unauthorized
Via:SIP/2.0/UDP 192.168.0.2:5060;branch=z9hG4bK8D36A1F
From:"MyTest"<sip:5551234567@sipconnect.dal0.cbeyond.net>;tag=5D0E3984-1CCB
To:<sip:1XXXXXXXXXX@sipconnect.dal0.cbeyond.net>;tag=1109735805-1282699203431
Call-ID:54680EC6-AF1E11DF-916C8E74-D60711A1@sipconnect.dal0.cbeyond.net
CSeq:101 INVITE
WWW-Authenticate:DIGEST qop="auth",nonce="BroadWorksXgd9hzjonT6dyj2BW",algorithm=MD5,realm="BroadWorks"
Content-Length:0
329322: *Aug 25 01:24:24.506: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:1XXXXXXXXXX@sipconnect.dal0.cbeyond.net:5060 SIP/2.0
Content-Length: 0
To: <sip:1XXXXXXXXXX@sipconnect.dal0.cbeyond.net>;tag=1109735805-1282699203431
CSeq: 101 ACK
Max-Forwards: 70
329323: *Aug 25 01:24:24.506: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Authorization: Digest
username="5551234567",realm="BroadWorks",uri="sip:1XXXXXXXXXX@sipconnect.dal0.cbeyond.net:5060",response="ed07fd5f574561091d4e95cb42f84b02",nonce="Broad
WorksXgd9hzjonT6dyj2BW",cnonce="BE20888B",qop=auth,algorithm=MD5,nc=00000001
Min-SE: 1800
Content-Length: 244
Expires: 180
Via: SIP/2.0/UDP 192.168.0.2:5060;branch=z9hG4bK8D371580
CSeq: 102 INVITE
Max-Forwards: 69
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=ptime:20
329324: *Aug 25 01:24:24.558: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via:SIP/2.0/UDP 192.168.0.2:5060;branch=z9hG4bK8D371580
CSeq:102 INVITE
Content-Length:0
329325: *Aug 25 01:24:27.011: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To:<sip:1XXXXXXXXXX@sipconnect.dal0.cbeyond.net>;tag=599900672-1282699205943
CSeq:102 INVITE
Allow:ACK,BYE,CANCEL,INFO,INVITE,OPTIONS,PRACK,REFER,NOTIFY
Supported:
Contact:<sip:bwas1-vir.atl0.cbeyond.net>
Content-Type:application/sdp
Content-Length:362
v=0
o=BroadWorks 202540560 1 IN IP4 192.168.44.145
s=-
c=IN IP4 192.168.44.145
t=0 0
m=audio 19206 RTP/AVP 0 101 100
a=fmtp:101 0-15
a=rtpmap:100 X-NSE/8000
a=fmtp:100 192-194,200-202
a=sqn:0
a=cdsc: 1 audio RTP/AVP 100
a=cpar: a=rtpmap:100 X-NSE/8000
a=cpar: a=fmtp:100 192-194,200-202
a=cdsc: 2 image udptl t38
329326: *Aug 25 01:24:27.011: //47959/546501659166/CCAPI/cc_api_caps_ind:
Destination Interface=0x0, Destination Call Id=-1, Source Call Id=47959,
Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
Modem=0x0, Codec Bytes=20, Signal Type=2)
329327: *Aug 25 01:24:27.015: //47959/546501659166/CCAPI/cc_api_caps_ind:
Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Playout Max=1000(ms), Fax Nom=300(ms))
329328: *Aug 25 01:24:27.015: //47958/546501659166/CCAPI/cc_api_caps_ack:
Destination Interface=0x0, Destination Call Id=-1, Source Call Id=47958,
Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=1)
329329: *Aug 25 01:24:27.015: //47959/546501659166/CCAPI/cc_api_event_indication:
Event=155, Call Id=47959
329330: *Aug 25 01:24:27.015: //47959/546501659166/CCAPI/cc_api_event_indication:
Event Is Sent To Conferenced SPI(s) Directly
329331: *Aug 25 01:24:27.015: //47959/546501659166/CCAPI/cc_api_call_alert:
Interface=0x85FBBD18, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1)
329332: *Aug 25 01:24:27.015: //47959/546501659166/CCAPI/cc_api_call_alert:
Call Entry(Retry Count=0, Responsed=TRUE)
329333: *Aug 25 01:24:27.015: //47958/546501659166/CCAPI/ccCallAlert:
329334: *Aug 25 01:24:27.015: //47958/546501659166/CCAPI/ccCallAlert:
Call Entry(Responsed=TRUE, Alert Sent=TRUE)
329335: *Aug 25 01:24:27.015: //47958/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
(confID=0x8902B884, callID1=0xBB56, callID2=0xBB57, tag=0x0)
329336: *Aug 25 01:24:27.015: //47958/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
(confID=0x8902B884, callID1=0xBB56, gcid=54659D8D-AF1E11DF-91698E74-D60711A1, tag=0x0)
329337: *Aug 25 01:24:27.015: //47959/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
(confID=0x8902B884, callID2=0xBB57, gcid=54659D8D-AF1E11DF-91698E74-D60711A1, tag=0x0)
329338: *Aug 25 01:24:27.015: //47958/546501659166/CCAPI/ccConferenceCreate:
Conference Id=0x8902B884, Call Id1=47958, Call Id2=47959, Tag=0x0
329339: *Aug 25 01:24:27.015: //47958/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
329340: *Aug 25 01:24:27.015: ccConferenceCreate: ret1=0, codecMask1=1, bytes1=160, negot1=1, dtmf1=8
ret2=0, codecMask2=1, bytes2=160, negot2=1, dtmf2=6,
tx_dynamic_pt1=0, rx_dynamic_pt1=0, codec_mode1=0, params_bitmap1 =0
tx_dynamic_pt2=0, rx_dynamic_pt2=0, codec_mode2=0, params_bitmap2 =0
329341: *Aug 25 01:24:27.015: //47958/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
delay media to slow start case, codec negotation is not done
329342: *Aug 25 01:24:27.015: //47958/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
329343: *Aug 25 01:24:27.015: cc_api_get_xcode_stream : 4534
329344: *Aug 25 01:24:27.015: //47958/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Conference Id=0x1827, Source Interface=0x85FBBD18, Source Call Id=47958,
Destination Call Id=47959, Disposition=0x0, Tag=0x0
329345: *Aug 25 01:24:27.019: //47959/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
329346: *Aug 25 01:24:27.019: cc_api_get_xcode_stream : 4534
329347: *Aug 25 01:24:27.019: //47959/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Conference Id=0x1827, Source Interface=0x85FBBD18, Source Call Id=47959,
Destination Call Id=47958, Disposition=0x0, Tag=0x0
329348: *Aug 25 01:24:27.019: //47958/546501659166/CCAPI/cc_generic_bridge_done:
329349: *Aug 25 01:24:27.019: //47958/546501659166/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x1827, Destination Call Id=47959)
329350: *Aug 25 01:24:27.019: //47959/546501659166/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x1827, Destination Call Id=47958)
329351: *Aug 25 01:24:27.019: //47958/546501659166/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x1827, Call Id1=47958, Call Id2=47959
329352: *Aug 25 01:24:27.023: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 183 Session Progress
Supported: sdp-anat
Content-Length: 186
To: <sip:915558091234@192.168.0.2>;tag=5D0E4390-1BAF
Contact: <sip:915558091234@192.168.0.2:5060>
CSeq: 1 INVITE
v=0
o=CiscoSystemsSIP-GW-UserAgent 2277 96 IN IP4 192.168.0.2
s=SIP Call
t=0 0
m=audio 19560 RTP/AVP 0
a=ptime:20
329353: *Aug 25 01:24:45.159: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq:102 INVITE
Supported:
Allow:ACK,BYE,CANCEL,INFO,INVITE,OPTIONS,PRACK,REFER,NOTIFY,UPDATE
Accept:multipart/mixed,application/media_control+xml,application/sdp
Content-Length:362
v=0
s=-
t=0 0
a=fmtp:101 0-15
a=sqn:0
329354: *Aug 25 01:24:45.163: //47959/546501659166/CCAPI/cc_api_call_connected:
Interface=0x85FBBD18, Data Bitmask=0x1, Progress Indication=NULL(0),
Connection Handle=0
329355: *Aug 25 01:24:45.163: //47959/546501659166/CCAPI/cc_api_call_connected:
Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
329356: *Aug 25 01:24:45.167: //47958/546501659166/CCAPI/ccCallConnect:
Progress Indication=NULL(0), Data Bitmask=0x1
329357: *Aug 25 01:24:45.167: //47958/546501659166/CCAPI/ccCallConnect:
Call Entry(Connected=TRUE, Responsed=TRUE)
329358: *Aug 25 01:24:45.171: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:bwas1-vir.atl0.cbeyond.net:5060 SIP/2.0
Content-Length: 0
To: <sip:1XXXXXXXXXX@sipconnect.dal0.cbeyond.net>;tag=599900672-1282699205943
Via: SIP/2.0/UDP 192.168.0.2:5060;branch=z9hG4bK8D381CC3
CSeq: 102 ACK
Max-Forwards: 70
329359: *Aug 25 01:24:45.171: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Supported: replaces
Supported: sdp-anat
Content-Length: 186
CSeq: 1 INVITE
v=0
s=SIP Call
t=0 0
a=ptime:20
329360: *Aug 25 01:24:45.175: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:915558091234@192.168.0.2:5060 SIP/2.0
CSeq: 1 ACK
Via: SIP/2.0/UDP 192.168.0.122:5060;branch=z9hG4bK-69a0e-19c9c6e2-1de1c729
Max-Forwards: 70
Content-Length: 0
This is when the recipient attempted to transfer the call.
329361: *Aug 25 01:25:16.172: s=VoIP d=DSP payload 0x65 ssrc 0x1B1F2C91 sequence 0xACFF timestamp 0x3B396E9C
329362: *Aug 25 01:25:16.172: <<<Rcv> Pt:101 Evt:2 Pkt:09 00 00
329363: *Aug 25 01:25:16.172: s=DSP d=VoIP payload 0x65 ssrc 0x1B1F2C91 sequence 0xACFF timestamp 0x3B396E9C
329364: *Aug 25 01:25:16.172: Pt:101 Evt:2 Pkt:09 00 00 <Snd>>>
329365: *Aug 25 01:25:16.172: s=VoIP d=DSP payload 0x65 ssrc 0x1B1F2C91 sequence 0xAD00 timestamp 0x3B396E9C
329366: *Aug 25 01:25:16.172: <<<Rcv> Pt:101 Evt:2 Pkt:09 00 00
329367: *Aug 25 01:25:16.172: s=DSP d=VoIP payload 0x65 ssrc 0x1B1F2C91 sequence 0xAD00 timestamp 0x3B396E9C
329368: *Aug 25 01:25:16.172: Pt:101 Evt:2 Pkt:09 00 00 <Snd>>>
329369: *Aug 25 01:25:16.172: s=VoIP d=DSP payload 0x65 ssrc 0x1B1F2C91 sequence 0xAD01 timestamp 0x3B396E9C
329370: *Aug 25 01:25:16.172: <<<Rcv> Pt:101 Evt:2 Pkt:09 00 00
329371: *Aug 25 01:25:16.172: s=DSP d=VoIP payload 0x65 ssrc 0x1B1F2C91 sequence 0xAD01 timestamp 0x3B396E9C
329372: *Aug 25 01:25:16.172: Pt:101 Evt:2 Pkt:09 00 00 <Snd>>>
329373: *Aug 25 01:25:16.172: //47959/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_begin:
Consume mask is not set. Relaying Digit 2 to dstCallId 0xBB56
329374: *Aug 25 01:25:16.172: //47959/xxxxxxxxxxxx/CCAPI/cc_relay_digit_begin_for_3way_conference:
Check DTMF relay digit begin for 3way conf
329375: *Aug 25 01:25:16.220: s=VoIP d=DSP payload 0x65 ssrc 0x1B1F2C91 sequence 0xAD02 timestamp 0x3B396E9C
329376: *Aug 25 01:25:16.220: <<<Rcv> Pt:101 Evt:2 Pkt:09 01 90
329377: *Aug 25 01:25:16.220: s=DSP d=VoIP payload 0x65 ssrc 0x1B1F2C91 sequence 0xAD02 timestamp 0x3B396E9C
329378: *Aug 25 01:25:16.220: Pt:101 Evt:2 Pkt:09 01 90 <Snd>>>
329379: *Aug 25 01:25:16.268: s=VoIP d=DSP payload 0x65 ssrc 0x1B1F2C91 sequence 0xAD03 timestamp 0x3B396E9C
329380: *Aug 25 01:25:16.268: <<<Rcv> Pt:101 Evt:2 Pkt:09 03 20
329381: *Aug 25 01:25:16.268: s=DSP d=VoIP payload 0x65 ssrc 0x1B1F2C91 sequence 0xAD03 timestamp 0x3B396E9C
329382: *Aug 25 01:25:16.268: Pt:101 Evt:2 Pkt:09 03 20 <Snd>>>
329383: *Aug 25 01:25:16.320: s=VoIP d=DSP payload 0x65 ssrc 0x1B1F2C91 sequence 0xAD04 timestamp 0x3B396E9C
329384: *Aug 25 01:25:16.320: <<<Rcv> Pt:101 Evt:2 Pkt:09 04 B0
329385: *Aug 25 01:25:16.320: s=DSP d=VoIP payload 0x65 ssrc 0x1B1F2C91 sequence 0xAD04 timestamp 0x3B396E9C
329386: *Aug 25 01:25:16.320: Pt:101 Evt:2 Pkt:09 04 B0 <Snd>>>
329387: *Aug 25 01:25:16.360: s=VoIP d=DSP payload 0x65 ssrc 0x1B1F2C91 sequence 0xAD05 timestamp 0x3B396E9C
329388: *Aug 25 01:25:16.360: <<<Rcv> Pt:101 Evt:2 Pkt:89 05 88
329389: *Aug 25 01:25:16.360: s=DSP d=VoIP payload 0x65 ssrc 0x1B1F2C91 sequence 0xAD05 timestamp 0x3B396E9C
329390: *Aug 25 01:25:16.360: Pt:101 Evt:2 Pkt:89 05 88 <Snd>>>
329391: *Aug 25 01:25:16.360: s=VoIP d=DSP payload 0x65 ssrc 0x1B1F2C91 sequence 0xAD06 timestamp 0x3B396E9C
329392: *Aug 25 01:25:16.360: <<<Rcv> Pt:101 Evt:2 Pkt:89 05 88
329393: *Aug 25 01:25:16.360: s=DSP d=VoIP payload 0x65 ssrc 0x1B1F2C91 sequence 0xAD06 timestamp 0x3B396E9C
329394: *Aug 25 01:25:16.360: Pt:101 Evt:2 Pkt:89 05 88 <Snd>>>
329395: *Aug 25 01:25:16.360: s=VoIP d=DSP payload 0x65 ssrc 0x1B1F2C91 sequence 0xAD07 timestamp 0x3B396E9C
329396: *Aug 25 01:25:16.360: <<<Rcv> Pt:101 Evt:2 Pkt:89 05 88
329397: *Aug 25 01:25:16.360: s=DSP d=VoIP payload 0x65 ssrc 0x1B1F2C91 sequence 0xAD07 timestamp 0x3B396E9C
329398: *Aug 25 01:25:16.360: Pt:101 Evt:2 Pkt:89 05 88 <Snd>>>
329399: *Aug 25 01:25:16.360: //47959/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_end:
329400: *Aug 25 01:25:16.360: //47959/xxxxxxxxxxxx/CCAPI/cc_relay_digit_end_for_3way_conference:
Check DTMF relay digit end for 3way conf
329401: *Aug 25 01:25:24.648: s=VoIP d=DSP payload 0x65 ssrc 0x1B1F2C91 sequence 0xAEA6 timestamp 0x3B3A7774
329402: *Aug 25 01:25:24.648: <<<Rcv> Pt:101 Evt:1 Pkt:0A 00 00
329403: *Aug 25 01:25:24.648: s=DSP d=VoIP payload 0x65 ssrc 0x1B1F2C91 sequence 0xAEA6 timestamp 0x3B3A7774
329404: *Aug 25 01:25:24.648: Pt:101 Evt:1 Pkt:0A 00 00 <Snd>>>
329405: *Aug 25 01:25:24.648: s=VoIP d=DSP payload 0x65 ssrc 0x1B1F2C91 sequence 0xAEA7 timestamp 0x3B3A7774
329406: *Aug 25 01:25:24.648: <<<Rcv> Pt:101 Evt:1 Pkt:0A 00 00
329407: *Aug 25 01:25:24.648: s=DSP d=VoIP payload 0x65 ssrc 0x1B1F2C91 sequence 0xAEA7 timestamp 0x3B3A7774
329408: *Aug 25 01:25:24.648: Pt:101 Evt:1 Pkt:0A 00 00 <Snd>>>
329409: *Aug 25 01:25:24.648: s=VoIP d=DSP payload 0x65 ssrc 0x1B1F2C91 sequence 0xAEA8 timestamp 0x3B3A7774
329410: *Aug 25 01:25:24.648: <<<Rcv> Pt:101 Evt:1 Pkt:0A 00 00
329411: *Aug 25 01:25:24.648: s=DSP d=VoIP payload 0x65 ssrc 0x1B1F2C91 sequence 0xAEA8 timestamp 0x3B3A7774
329412: *Aug 25 01:25:24.648: Pt:101 Evt:1 Pkt:0A 00 00 <Snd>>>
329413: *Aug 25 01:25:24.648: //47959/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_begin:
Consume mask is not set. Relaying Digit 1 to dstCallId 0xBB56
329414: *Aug 25 01:25:24.648: //47959/xxxxxxxxxxxx/CCAPI/cc_relay_digit_begin_for_3way_conference:
329415: *Aug 25 01:25:24.696: s=VoIP d=DSP payload 0x65 ssrc 0x1B1F2C91 sequence 0xAEA9 timestamp 0x3B3A7774
329416: *Aug 25 01:25:24.696: <<<Rcv> Pt:101 Evt:1 Pkt:0A 01 90
329417: *Aug 25 01:25:24.696: s=DSP d=VoIP payload 0x65 ssrc 0x1B1F2C91 sequence 0xAEA9 timestamp 0x3B3A7774
329418: *Aug 25 01:25:24.696: Pt:101 Evt:1 Pkt:0A 01 90 <Snd>>>
329419: *Aug 25 01:25:24.744: s=VoIP d=DSP payload 0x65 ssrc 0x1B1F2C91 sequence 0xAEAA timestamp 0x3B3A7774
329420: *Aug 25 01:25:24.744: <<<Rcv> Pt:101 Evt:1 Pkt:0A 03 20
329421: *Aug 25 01:25:24.744: s=DSP d=VoIP payload 0x65 ssrc 0x1B1F2C91 sequence 0xAEAA timestamp 0x3B3A7774
329422: *Aug 25 01:25:24.744: Pt:101 Evt:1 Pkt:0A 03 20 <Snd>>>
329423: *Aug 25 01:25:24.792: s=VoIP d=DSP payload 0x65 ssrc 0x1B1F2C91 sequence 0xAEAB timestamp 0x3B3A7774
329424: *Aug 25 01:25:24.792: <<<Rcv> Pt:101 Evt:1 Pkt:0A 04 B0
329425: *Aug 25 01:25:24.792: s=DSP d=VoIP payload 0x65 ssrc 0x1B1F2C91 sequence 0xAEAB timestamp 0x3B3A7774
329426: *Aug 25 01:25:24.792: Pt:101 Evt:1 Pkt:0A 04 B0 <Snd>>>
329427: *Aug 25 01:25:24.832: s=VoIP d=DSP payload 0x65 ssrc 0x1B1F2C91 sequence 0xAEAC timestamp 0x3B3A7774
329428: *Aug 25 01:25:24.832: <<<Rcv> Pt:101 Evt:1 Pkt:8A 05 90
329429: *Aug 25 01:25:24.832: s=DSP d=VoIP payload 0x65 ssrc 0x1B1F2C91 sequence 0xAEAC timestamp 0x3B3A7774
329430: *Aug 25 01:25:24.832: Pt:101 Evt:1 Pkt:8A 05 90 <Snd>>>
329431: *Aug 25 01:25:24.832: s=VoIP d=DSP payload 0x65 ssrc 0x1B1F2C91 sequence 0xAEAD timestamp 0x3B3A7774
329432: *Aug 25 01:25:24.832: <<<Rcv> Pt:101 Evt:1 Pkt:8A 05 90
329433: *Aug 25 01:25:24.832: s=DSP d=VoIP payload 0x65 ssrc 0x1B1F2C91 sequence 0xAEAD timestamp 0x3B3A7774
329434: *Aug 25 01:25:24.832: Pt:101 Evt:1 Pkt:8A 05 90 <Snd>>>
329435: *Aug 25 01:25:24.832: s=VoIP d=DSP payload 0x65 ssrc 0x1B1F2C91 sequence 0xAEAE timestamp 0x3B3A7774
329436: *Aug 25 01:25:24.832: <<<Rcv> Pt:101 Evt:1 Pkt:8A 05 90
329437: *Aug 25 01:25:24.832: s=DSP d=VoIP payload 0x65 ssrc 0x1B1F2C91 sequence 0xAEAE timestamp 0x3B3A7774
329438: *Aug 25 01:25:24.832: Pt:101 Evt:1 Pkt:8A 05 90 <Snd>>>
329439: *Aug 25 01:25:24.832: //47959/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_end:
329440: *Aug 25 01:25:24.832: //47959/xxxxxxxxxxxx/CCAPI/cc_relay_digit_end_for_3way_conference:
Solved! Go to Solution.
08-25-2010 12:34 PM
Changing the CUE DTMF is so you don't break DTMF for CUE outcall scenarios, since the dial-peer that will be matched for these calls will now expect RTP-NTE.
