Headset for SPA Phones
dedennis
Please advise the best headset for the SPA phones we have sold P
lantronics C555 with the lifter and cusotmers are not happy with them on the SPA phones, please suggest a good
wireless headset.
Alberto Montilla
Dear Sir;
Please see attached link, shows all headsets compatible with SPA phones, https://supportforums.cisco.com/docs/DOC-9926
Look at high end headsets, any of those should be good. Is is there any specific complain from the customer?
Alberto
David Trad
Hi Dennis,
Verified Headsets are as follows:
GN-Netcomm: GN2000NC
Attachement Required: Part# 8800-00-75
GN-Netcomm: GN2120NC
You need to purchase the 2.5mm Audio Jack cable so that way it plugs into it otherwise it comes with the RJ11 connector and or the 3.5mm Audio Jack.
These headsets are also referred to as Jabra as well, and should be available world wide, check with a local distributor to see if they stock it.
If you are wanting Bluetooth then the best possible fit would be as follows:
Plantronics Voyager Pro Part# code 402522
Again this should be available world wide from what I can see, also all the above headsets will work with 7900 series phones and above as well, you will just need to change the second part of the card to suit the particular phones module or form of connection.
Hope this helps
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
