05-18-2012 08:36 AM - edited 03-21-2019 05:48 AM
Can a page be sent to all the idle phones at a site? Ideally, the customer would like to use phones to broadcast a page throughout a facility. What are the options on a BE3K?
*Partner Question*
05-18-2012 08:40 AM
This is supported using multicast in the CUAC-CE attendant console and this solution is being validated in the upcoming 8.6.4 release. You will need 1 additional enhanced license for each user looking to utilize the attendant console software. One alternative is to use overhead paging with 3rd party analog paging hardware connected via FXS interface on a SPA 8800.
06-15-2012 09:03 AM
We had a CUBE router with an FXS card which worked well. We set up a dial-peer on the router that could be speed-dialed with a "paging" number on the attendant's phone and would call with auto-answer to the paging interface.
Jim
07-03-2012 12:05 AM
Is anyone able to answer the initial question with a yes or no?
Can you page idle handsets like you can with every other phone system on the market (or like you can with the UC500 series) This is a very basic and widely used function!
07-03-2012 08:57 AM
By "idle" do you mean, the phone is assigned to a user but is currently not active on a call.
As long as a phone is assigned to a user or department and is registered with BE3K, it can be target of a page. The phone should also support XML.
08-08-2012 08:26 PM
We just recieved our BE3k and the only way I seem to be able to make a page is by using Cisco Unified Attendent Compact Edition - what am I doing wrong? This takes quite a few mouse clicks one per user you want to page (or you make a group but that take up a lot of screen space - the group has to be expanded to select page) and then you have press and hold a button down on the phone while you talk? It's REALLY clunky..
08-08-2012 08:56 PM
Currently unicast or multicast paging is supported using compact edition of attendant console. So if you have that working, you are not missing anything. I agree with you that it is not as simple as picking up the phone, press a page button or softkey, and page.
In the upcoming release, we are planning to add paging from phones.
12-04-2012 12:56 PM
Do you know the time frame of when this new release will happen?
12-04-2012 07:36 PM
We are looking at a tentative release sometimes in 2nd half of CY 2013.
01-04-2013 04:04 PM
Thank you for your reply. Aside from paging from the phones. Do you know if all phones will be supported to make and receive pages? Also, does this mean that you will not need to have attendant console licenses to make these pages as well?
Thanks.
01-04-2013 04:05 PM
In addition to my last reply, the phone i'm particularly asking about is the 3905. We've bought a bunch of them for cost savings for those who don't need multiple lines. The only other thing that would be needed would be paginig capability.
Thanks.
01-04-2013 04:11 PM
Just to clarify NONE of the phones can initiate a page without the attendant software running on a PC. Really the BE3k is not a system for a company that needs paging.
01-04-2013 04:16 PM
Sorry, meant to hit your reply not mine. According to Sanjay, it's suppose to be added second half of this year.
01-04-2013 04:15 PM
Yes, i'm aware of that. I do have it working using the attendent console. I'm replying to what Sanjay stated that in the upcoming release, the are planning to add paging from phones.
Currently Being Moderated
Aug 8, 2012 9:56 PM (in response to Tim Austin-Mills)
How is group paging implemented in BE3000?Currently unicast or multicast paging is supported using compact edition of attendant console. So if you have that working, you are not missing anything. I agree with you that it is not as simple as picking up the phone, press a page button or softkey, and page.
06-10-2013 06:06 PM
Trying to revisit this discussion. Since we are just about entering the 2nd half of 2013, how close is Cisco to release the new software that will allow paging from phones?
