04-02-2012 04:50 PM - edited 03-21-2019 05:36 AM
CCA allows for traffic shapping for Voice traffic; however, it has a note that this is only for upload. How can you control or reserve bandwidth for Voice download?
04-02-2012 04:53 PM
Traffic policing on the WAN cannot be done using CCA.
04-03-2012 12:03 AM
You could configure traffish shaping (note, not policing) on the VLAN interface. That will have effect only for TCP traffic, but is effective enough in most cases.
Configuring and verifying that is strictly a CLI task.
04-03-2012 02:03 PM
Hi Dave,
Sorry if the question is a bit simplistic or obvious.
What are you trying to achieve? Can you give us a full run down of what you want to do and the final goal, this way I can at least see what options are available for you.
Cheers,
David.
