How to open outbound firewall ports in UC520
adamvayle
I use a UC520 as my router, DHCP server and have NAT and the firewall turned ON.  I need to open some external ports in the firewall for Microsoft Lync, specifically:
Ports Needed Open in External Firewall
Port
Protocol
Direction
Usage
443
STUN/TCP
Outbound
Audio, video, and application sharing sessions
443
PSOM/TLS
Outbound
Data sharing sessions
3478
STUN/UDP
Outbound
Audio and video sessions
50000-59999
RTP/UDP
Outbound
Is there a way to do this in the UC520?  There are NO other routers between the UC520 and the Internet.  I only need the ports to be OUTBOUND, i.e. open going from the LAN to the WAN (or Internet).
Adam Vayle
6 Replies 6
b_rasheed
There are two methods:
1. this will open any ports on the destination device
    ip nat inside source static
2. this will open per tcp/udp port
ip nat inside source static tcp 443 443
pierrescotland
I think by default you'll find all outbound traffic is allowed anyway, I usually do not use the ethernet WAN port, but I'm pretty sure this is the case.   What the above post opens up is Inbound static NAT, which is not what you're looking for I believe.
Are you receiving an error when running Lync?
I am getting the following error when trying to login to Lync:
"Cannot sign in to Lync.  There was a problem acquiring a personal certificate required to sign in. "
I wanted to make sure I had the right ports open before contacting Microsoft support. I was thinking all outbound ports might be open by default, but wasn't sure.  Can anyone confirm this?
Thanks.
The error you're getting does not seem firewall-related anyway, try this:-
to fix it would be to go under the " Admin " Page, Then "Users" under  management, Then click on the box of the users name, Click on License  and Uncheck the "Lync" Box , Save then go back to the same user and then  re-apply the "lync" license. It should re-create a lync account for  that user. Now after you do that you need to give it about 5 to 10 mins,  best way to tell to try it would be to look under the "More" Option and  you'll see the lync "Change user settings" go from grey to blue,  meaning that the user account has been established and is reay for  config
David Trad
Hi Adam,
I know you have already got some wonderful posts, I thought I would throw in a CCA mix on this, if you use CCA to do this it is a seamless process and it will not only configure the NAT it can help you with any Firewall Settings and in some cases even with NAT applied you might still need to make sure there are some ACL's in place (Depending on what it is you are doing).
Have a look at this screen shot of NAT configuration in CCA 3.1.1:
It is quite a simple process to use CCA and there is some pretty good control as to how it needs to work.
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
Thanks to everyone for their replies.  Interestingly, Lync suddenly started working all by itself.  I hadn't even made any changes to the UC520 yet.  So, it looks like it was a Microsoft Lync server problem in the cloud.  I guess this means the outbound ports are open by default.
