How to Transfer directly to Voicemail
jrushing
I am having trouble transferring directly to voicemail. My device is the Cisco 8861 Gigabit Color Business Phone and it has the CP-BEKEM 8800 VoIP IP Phone Key Expansion connected on the side. I want to determine how to transfer to the VM of other employees at our company without it ringing their line. I found online that you can select BlindXfer then *55 then choose the extension. But when I click *5 (before I can select the '5' again) it automatically declines my request. Is there a different way I can do this operation?
John Steele
Are you using Webex Calling or Cisco Unified Communications Manager?  With Webex calling, that should always work. (Feature access codes for Webex Calling)
If it's Cisco Unified Communications Manager you can set it up with these instructions.
Transfer Calls Directly to Voice Mail with Cisco Unified Communications Manager - Cisco
