I'm looking at a the UC300 as a possible replacement for some asterisk PBXs I support.
However, a key feature that I need is the ability to route/block incoming calls based on incoming caller ID.
Is it possible to configure the UC300 in such a way that incoming calls that have an unknown caller id, or a blocked caller id, or who's caller ID matches a specific list would be routed directly to a voicemail box?
Basically, my clients get nuisance callers that disrupt their business and need to be able to route those calls to a VM box without ringing an extension.
I searched through the forums and there are some references to this sort of feature from back in 2010 and 2011, but nothing since.
Has it been added? if not, is it on the roadmap for a future release? if so, when?
thanks.
