intervlan routing
dflores83
I have a new UC520 and have a problem with inter-Vlan communication, I do 3 vlan but,   I can´t ping the vlan4 fron vlan 1
And from the laptop I can´t connect to Wvlan (vlan 4)
I attachment the config
thanks
6 Replies 6
dlkoch
You have the wrong default-router in you DHCP scopes
ip dhcp pool data
   network 192.168.10.0 255.255.255.0
   default-router 192.168.1.1   SHOULD BE 192.168.10.1
   dns-server 192.168.1.1 192.168.1.1
ip dhcp pool video
   network 192.168.12.0 255.255.255.0
   default-router 192.168.1.1   SHOULD BE 192.168.12.1
thnaks,
but
I was thinking, tah mabe should be a NAT problem??
some suggestion
I am not sure what you mean by a NAT problem.  The advice given is correct.  Change the default gateway on the pool and this should work.
And you dont specify a nat pool of address either.  You show pool 1 but there is no pool of address.
hi
I change the default route, thanks.
but
I do traceroute into two address
destination 192.168.12.3  source 192.168.10.12
the said that gateway don´t know the subnet 192.168.10.1
Do you have other devices in the network?  I am not sure how when you traceroute from a 192.168.10.0/24 address you get that the gateway doesn't know about 192.168.10.1.
Can you show a topology?  Also, can you show the switchport configuration?  How are the devices connecting to the UC500?
