Hi AllI recently purchased an spa921 ip phone but it was locked. When i tried to reset it to factory defaults it asked me for a password. Is there anyway to flash this phone without having to enter an admin password?
Hi, Can we configure IPCC Server with UC500, if yes please share a document for the same.Regards,Govind
Hello,I've encountered a problem with configuration of SPA9000 and Phone Book in SPA942.Example:we want to add new entry to dial an external number:616690724In order to make an outbound call in default we need to dial 9, so the entry in Phone book sh...
Hello,I am currently working on configuring SNR with 7.1.0EA software pack. I have a couple questions however:If you enter just the mobility command under the ephone-dn and leave out the SNR command, users are unable to enable and configure the SNR n...
i am trying to set up a multi-site configuration on our UC500 over an mpls network. Our main office has the UC500 the offsite location will have a catalyst 3560. How do i set up the ip phones attached to the 3560 in the offsite location to be able to...
Hi,I've setup a SIP trunk on the SPA9000, but where can I define the outgoing caller id for the phones??? Every phone (or ext) shows the registered username of the sip trunk (btw, it's the customers primary phone number).RegardsEivind
Hi, I'm new to CISCO equipment and would like to explore the possibility of using SPA9000 / SPA400 to implement a call forwarding feature that rings more than one external number and connect to the first phone answered.May I know if this is possible?...
I have had the following problem at a couple (not all) of my installations (SPA9000 + SPA400 + SPA962 + SPA942 -AT&T Chicago area PSTN only):Fairly often when the user dials the complete called number (e.g. 312 55-1212) not all of the digits make it ...
I have a UC500 with SIP trunk. I have intermitent voice qualtity problems in the form of broken speech, typically on the far end.The SIP trunk provider claims the issue is not with him and points to widely varying ping times from his server to my UC5...
I am trying to figure out how to have the appropriate access code inserted for replying to calls. When my users want to reply to missed calls, they want to simply hit dial. That doesn't work though as the system is configured to require a 9 for outbo...
Hi,i have the spa941 connected to an wbp54g and this one is connected to a wrt54g but dont work. the buttons on the spa 941 keep orange.but when i connect the spa941 with the wbp54g to an 2wire router works fine.(in both cases the wbp54g has been con...
hi guys,i have question regarding corlist setup. can we setup this based on the ephone-dn instead of ephone. for example, there are 2 offices, office A has extension 100 and 101 and the phone number is 111-2222. then office B has extension 200 and 20...
Hi,I´m wondering if it´s possible to get the dial-peer and translation profile for sweden in a text file? We have a customer with a 2811 CME router in sweden and I´m not familiar with the swedish dial-plan. The dial-peer should be for a SIP trunk, an...
Hello!I must connect to more then one sip provider but if i add a secound authentification i get follwing answer:UC520(config-sip-ua)#authentication username 1501225 password abcdeOnly one username per device supportedPlease unconfigure previous auth...
We're getting this Java error when CCA loads the voice section. It gets about 70% of the way and then stops loading and returns the above error. The java debug console shows the following details:java.lang.NullPointerException at jav...
