IP softphone vs IP communicator.......
abhishek.shah
HI everyone,
Can any one tell me what is the difference between IP softphone and IP communicator????? How can i configured on my UC 520???
6 Replies 6
Steven DiStefano
Cisco IP Communicator is the lowest cost phone in out portfolio (list $90) and is our soft phone, and looks like a 7970.
The MODEL in CCA is is CIPC and it is built the same as any phone.
IP communicator gets ip from a dhcp 192.168.10.11. when i tried to conifgure button through CME gui there is no option for button???? seems abnormal
then i tried to configure through CCA it gives me the option configure it but doesnt shown up on CIPC. how i can configure users on CIPC???/
THanks
Check out Technical Enablement Lab #25 in this community (search will find it) There is a user (Dwight Schrute) that is a CIPC that we use CCA to configure.
Remember to set the Preferences on CIPC for 10.1.1.1 network (Voice VLAN dGW) and select the wired Ethernet interface.
https://supportforums.cisco.com/docs/DOC-9836
My ip communicator didnt get registered.
This is my show ephone cli
ephone-3[2] Mac:0006.5BB8.B38A TCP socket:[-1] activeLine:0 whisperLine:0 DECEAS
ED
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 res
et_sent:0 paging 0 debug:0 caps:0
IP:192.168.10.11 * 1038 Unknown 0  keepalive 0 max_line 0 available_line 0
Preferred Codec: g711ulaw
Lpcor Type: none
I go through preference set the tftp server 10.1.1.1 and select nic. go to n/w auto select ip. plz help me out with this. i dont know from where to start.
Thanks.
Make sure you only have one NIC active
Steve DiStefano
Technical Solutions Architect - Partner Sales, USA
Cisco Systems
7025 Kit Creek Road
Research Triangle Park
North Carolina, 27709
1.919.392.6219
sdistef@cisco. com
www.cisco.com/smb
i have only one nic 3com 3c920 fastethernet controller. Did my audio card needs to get ip??? by default it gets from DHCP.
ED
Lpcor Type: none
DECEASED what it means??? why its not getting ip address from voice vlan ???
it gets ip address of my connected laptop 192.168.10.11. if u need i can send u debug..
