04-02-2012 02:53 AM - edited 03-21-2019 05:35 AM
I have problems with caller id. it is not visualized in my system (UC320W 2.1.4(3) , 3 x SPA303 , SPA8800)
i try this:
reset and reconfigure
update 2.2.2 with factory default and reconfigure
only fxo0 (0 number of line) visualized in spa303
line in UC320W or in SPA8800 is the same
Thank You
Thomas
04-02-2012 07:10 AM
Hi Thomas,
Have you tried running the FXO impedance matching on each of your FXO lines. Go to the FXO screen and select the Impedance matching button. It will take 7 -9 minutes per line to run. This helps tune the system to the FXO characteristics.
If you have done the tuning and verified that you can get caller ID by plugging in a analog phone with caller id to the line, then I would suggest contacting the Cisco Small Business Support center where they can run some other diagnostics.
Chris
04-03-2012 06:27 AM
Thank you for support
i will contact Cisco Small Business Support center
Thomas
