Linksys SPA942 - DND Question
mikep2629
I'm wondering if it's possible to set DND on a specific extension instead of having to enable/disable an extension when not being used?
Mike
Dan Lukes
SPA942 is SPA IP Phone. Please use blue [ EDIT ] button on top and move this question to Small Business Support Community -> Cisco Small Business Support Community -> SPA IP Phones
Thanks, done that.  Sorry for getting the wrong forum.
Dan Lukes
I vaguely remember the ancient thread related to this where Patrick Born from Cisco has explained that's not possible to set both DND as well as Call Forwarding "per line". But I failed to found such thread. Instead I found this one: Forwarding all lines on SPA962/SPA942 claiming the DND works on Line 1 only.
All at all it's not user configurable behavior, although it may be firmware version specific.
If you are dissatisfied with the embedded DND behavior it may be possible to implement your own using PSK keys (if both VoIP providers have DND supplementary service implemented).
