Multiple phones, single voicemail box?
JOHN THIEN
I have one user that will be using four phones, depending on where he is in the building.
Is there a way to have a single voicemail box for him, that will alert him on all four phones if there is a voicemail waiting?
paolo bevilacqua
There is no easy way. However you can use use either a shared line appearing on multiple phones, or Extension Mobility.
I setup the voicemail notification to E-Mail, so I think he will be satisfied that at least all the voicemail will be sent as wav files to a common E-Mail address.  Thanks for the help.
Thank you for the nice rating and good luck!
