02-26-2012 02:40 AM - edited 03-21-2019 05:25 AM
I have a 7925 wireless IP-Phone connected to my UC540.
I got a problem with the softkeys. In idle mode all options are visible on the phone.
When a call is connected I only see two blank softkeys,without any options.
The phone button template is the following:
ephone-template 16
url services 1 http://10.1.10.1/voiceview/common/login.do VoiceviewExpress
softkeys remote-in-use Newcall
softkeys idle Redial Newcall Cfwdall Pickup Gpickup Dnd Login
softkeys seized Cfwdall Endcall Redial Pickup Gpickup Callback
softkeys connected Hold Endcall Trnsfer TrnsfVM Confrn Acct Park
Any idea?
Bye Stefan
02-26-2012 07:06 AM
Hi Stefan,
Are you using localization pack?
Best regadrs,
Alex
02-26-2012 11:25 AM
Hi Alex,
yes, I´m using German localization pack.
I made a test by editing the menu objects in different modes.
I added options step by step, when I e.g add mobility in idle, all options disappear in idle mode.
Which problem can cause this?
Bye Stefan
02-26-2012 12:11 PM
Hi Stefan,
Single Number Reach -SNR calls is only supported in US English locale - CME Admin Guide p. 1284. CCA Admin Guide also refers to it. Please take a look on this link:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmesnr.html#wp1011757
Best regards,
Alex
*Please rate helpful posts
02-26-2012 08:51 PM
I had the exact same problem a few weeks ago. Cisco recreated the template for me apparantly they need to be in a specific order.
The below template got this working for me again.
ephone-template 3
service phone webAccess 0
softkeys hold Join Newcall Resume Select
softkeys alerting Callback Endcall
softkeys connected Hold Endcall Trnsfer TrnsfVM Confrn Join Select ConfList
softkeys ringing Answer Dnd
