06-11-2013 12:32 PM - 편집 03-21-2019 07:27 AM
Now that the SR520 as well as the SA500 series are EoL/EoS, what is the officially supported equipment (ie. configurable through CCA) for small teleworker and remote offices using the UC500 SBCS system? Is it the ISA500?
날짜: 06-12-2013 07:51 AM
Hi ckent1111, thank you for using our forum, my name is Luis I am part of the Small business Support community. As far I know CCA doesn't support ISA products
I hope you find this answer useful
Greetings,
Luis Arias.
Cisco Network Support Engineer.
날짜: 06-12-2013 08:11 AM
Dear Partner,
Thank you for reaching Cisco Small Business Support Community.
The ISA570W or the RV215W would be the best equipment to get that combines highly secure Internet, wireless, site-to-site, and remote access VPN plus many other features to accomplish today's needs and challenges. Please refer to their datasheets for details
ISA500 series datasheet;
http://www.cisco.com/en/US/prod/collateral/vpndevc/ps11850/ps11752/data_sheet_c78-717565.html
RV215W datasheet;
http://www.cisco.com/en/US/prod/collateral/routers/ps10907/ps9923/ps12678/data_sheet_c78-712088.html
Please let me know if there is anything else we may assist you with.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
새로운 아이디어를 발견하고 저장하세요. 전문가 답변, 단계별 가이드, 최근 주제 등 다양한 내용을 확인해 보세요.
처음이신가요? 아래 팁들을 확인해 보세요. 시스코 커뮤니티 사용하기 새 멤버 가이드
