one spa8800 with 3 spa8000
mkbistania
Hi ALL,
I have four locations with local PBX installed and all locations are connected over LAN with same IP segment. Also i have four PSTN lines at one location. Now I want the analouge telephone systems to call each other over local numbers and can also dial outside using the PSTN lines. Please let me the way to configure it, I dont have any SIP server and i want to use these ATA devices only fot this setup.
Manoj
paolo bevilacqua
Wrong forum, post in "Small business, ATA and gateways". You can move your post using the actions panel on the right.
