Only 3 Ring Tones Are Listed
jaydien1358
Level 3
Level 3
I am currently running 7.0.1 on my UC. When I go into ring type on my 7960 phone, I am unable to pull up any ring tones.
Under Ring Type, when I select a line, it says "Requesting Ring List", then eventually just says 'Ring List Unavailable'.
I've uploaded a new copy of RingList.xml and DistinctiveRingList.xml, but it hasn't fixed the issue.
Please advise. Thanks
-Brian
www.jaydien.com
5 Replies 5
Douglas Smith
Hi Brian,
Be sure you have the phone loads in flash:/phones/79xx/ folders and in the config the following should appear for each phone type.If you have any question regarding the syntax please use the default configs found in the load zip file as a reference.
tftp-server flash:/phones/7970_7971/SCCP70.8-3-5S.loads alias SCCP70.8-3-5S.loads
tftp-server flash:/phones/7970_7971/term70.default.loads alias term70.default.loads
tftp-server flash:/phones/7970_7971/term71.default.loads alias term71.default.loads
tftp-server flash:/phones/7970_7971/cnu70.8-3-4-16.sbn alias cnu70.8-3-4-16.sbn
tftp-server flash:/phones/7970_7971/apps70.8-3-4-16.sbn alias apps70.8-3-4-16.sbn
tftp-server flash:/phones/7970_7971/dsp70.8-3-4-16.sbn alias dsp70.8-3-4-16.sbn
tftp-server flash:/phones/7970_7971/jar70sccp.8-3-4-16.sbn alias jar70sccp.8-3-4-16.sbn
tftp-server flash:/phones/7970_7971/cvm70sccp.8-3-4-16.sbn alias cvm70sccp.8-3-4-16.sbn
tftp-server flash:/phones/7975/SCCP75.8-3-5S.loads alias SCCP75.8-3-5S.loads
tftp-server flash:/phones/7975/cnu75.8-3-4-16.sbn alias cnu75.8-3-4-16.sbn
tftp-server flash:/phones/7975/term75.default.loads alias term75.default.loads
tftp-server flash:/phones/7975/apps75.8-3-4-16.sbn alias apps75.8-3-4-16.sbn
tftp-server flash:/phones/7975/dsp75.8-3-4-16.sbn alias dsp75.8-3-4-16.sbn
tftp-server flash:/phones/7975/cvm75sccp.8-3-4-16.sbn alias cvm75sccp.8-3-4-16.sbn
tftp-server flash:/phones/7975/jar75sccp.8-3-4-16.sbn alias jar75sccp.8-3-4-16.sbn
telephony-service
  load 7970 SCCP70.8-2-2SR2S
load 7975 SCCP75.8-3-2S
Douglas Smith
Customer Support Engineer
Small Business Systems Business Unit
Here is how my IOS CLI looks in regard to the TFTP-Server lines. As you can see, they do not reflect the actual flash directory structure at all.
tftp-server flash:cmterm-7941-7961-sccp.7.0.3.tar
tftp-server flash:jar11sccp.8-0-2-25.sbn
tftp-server flash:cvm11sccp.8-0-2-25.sbn
tftp-server flash:dsp11.1-1-2-26.sbn
tftp-server flash:cnu11.3-1-2-26.sbn
tftp-server flash:apps11.1-1-2-26.sbn
tftp-server flash:cnu70.2-7-6-26.sbn
tftp-server flash:CVM70.2-0-2-26.sbn
tftp-server flash:Jar70.2-9-2-26.sbn
tftp-server flash:Jar41.2-9-2-26.sbn
tftp-server flash:CVM41.2-0-2-26.sbn
tftp-server flash:cnu41.2-7-6-26.sbn
tftp-server flash:SYS-1.0.4.SBN
tftp-server flash:TNUX-1.0.4.SBN
tftp-server flash:TNUXR-1.0.4.SBN
tftp-server flash:APPS-1.0.4.SBN
tftp-server flash:TNUXR-1.0.1.SBN
tftp-server flash:GUI-1.0.4.SBN
tftp-server flash:SYS-1.0.1.SBN
tftp-server flash:WLAN-1.0.4.SBN
tftp-server flash:APPS-1.0.1.SBN
tftp-server flash:TNUX-1.0.1.SBN
tftp-server flash:WLAN-1.0.1.SBN
tftp-server flash:GUI-1.0.1.SBN
tftp-server flash:cvm31sccp.8-1-0-90.sbn
tftp-server flash:jar31sccp.8-1-0-90.sbn
tftp-server flash:apps31.8-1-0-89.sbn
tftp-server flash:dsp31.8-1-0-89.sbn
tftp-server flash:cnu31.8-1-0-89.sbn
tftp-server flash:P0030702T023.sbn
tftp-server flash:P0030702T023.sb2
tftp-server flash:P0030702T023.bin
tftp-server flash:cp524g-08-01-07.bin
tftp-server flash:SIP3951.8-0-2-0.zz
tftp-server flash:BOOT3951.0-0-0-9.zz
tftp-server flash:DSP3951.0-0-0-2.zz
tftp-server flash:SIP3951.8-1-2-0.zz
tftp-server flash:dsp11.8-2-2TR2.sbn
tftp-server flash:cvm11sccp.8-2-2TR2.sbn
tftp-server flash:apps11.8-2-2TR2.sbn
tftp-server flash:jar11sccp.8-2-2TR2.sbn
tftp-server flash:cnu11.8-2-2TR2.sbn
tftp-server flash:SCCP11.8-2-2SR2S.loads
tftp-server flash:term06.default.loads
tftp-server flash:term11.default.loads
tftp-server flash:SCCP70.8-2-2SR2S.loads
tftp-server flash:apps70.8-2-2TR2.sbn
tftp-server flash:term71.default.loads
tftp-server flash:dsp70.8-2-2TR2.sbn
tftp-server flash:term70.default.loads
tftp-server flash:cvm70sccp.8-2-2TR2.sbn
tftp-server flash:cnu70.8-2-2TR2.sbn
tftp-server flash:jar70sccp.8-2-2TR2.sbn
tftp-server flash:dsp41.8-2-2TR2.sbn
tftp-server flash:SCCP41.8-2-2SR2S.loads
tftp-server flash:term41.default.loads
tftp-server flash:cvm41sccp.8-2-2TR2.sbn
tftp-server flash:cnu41.8-2-2TR2.sbn
tftp-server flash:term61.default.loads
tftp-server flash:apps41.8-2-2TR2.sbn
tftp-server flash:jar41sccp.8-2-2TR2.sbn
tftp-server flash:CP7902080002SCCP060817A.sbin
tftp-server flash:term62.default.loads
tftp-server flash:term42.default.loads
tftp-server flash:cnu42.8-3-1-22.sbn
tftp-server flash:cvm42sccp.8-3-1-22.sbn
tftp-server flash:dsp42.8-3-1-22.sbn
tftp-server flash:jar42sccp.8-3-1-22.sbn
tftp-server flash:SCCP42.8-3-2S.loads
tftp-server flash:apps42.8-3-1-22.sbn
tftp-server flash:GUI-1.2.1.SBN
tftp-server flash:TNUX-1.2.1.SBN
tftp-server flash:SYS-1.2.1.SBN
tftp-server flash:APPS-1.2.1.SBN
tftp-server flash:CP7921G-1.2.1.LOADS
tftp-server flash:WLAN-1.2.1.SBN
tftp-server flash:TNUXR-1.2.1.SBN
tftp-server flash:S00105000200.sbn
tftp-server flash:cmterm_7936.3-3-13-0.bin
tftp-server flash:term31.default.loads
tftp-server flash:dsp31.8-2-2TR2.sbn
tftp-server flash:cvm31sccp.8-2-2TR2.sbn
tftp-server flash:apps31.8-2-2TR2.sbn
tftp-server flash:cnu31.8-2-2TR2.sbn
tftp-server flash:jar31sccp.8-2-2TR2.sbn
tftp-server flash:SCCP31.8-2-2SR2S.loads
tftp-server flash:dsp75.8-3-1-22.sbn
tftp-server flash:term75.default.loads
tftp-server flash:jar75sccp.8-3-1-22.sbn
tftp-server flash:cnu75.8-3-1-22.sbn
tftp-server flash:apps75.8-3-1-22.sbn
tftp-server flash:SCCP75.8-3-2S.loads
tftp-server flash:cvm75sccp.8-3-1-22.sbn
tftp-server flash:cvm45sccp.8-3-1-22.sbn
tftp-server flash:apps45.8-3-1-22.sbn
tftp-server flash:dsp45.8-3-1-22.sbn
tftp-server flash:term45.default.loads
tftp-server flash:cnu45.8-3-1-22.sbn
tftp-server flash:term65.default.loads
tftp-server flash:jar45sccp.8-3-1-22.sbn
tftp-server flash:SCCP45.8-3-2S.loads
tftp-server flash:P00308000500.sbn
tftp-server flash:P00308000500.bin
tftp-server flash:P00308000500.sb2
tftp-server flash:P00308000500.loads
tftp-server flash:SIP3951.8-1-2.loads
tftp-server flash:cp524g-08-01-12.bin
tftp-server flash:AA_SBCS_v01.aef
tftp-server flash:AA_transfer.aef
tftp-server flash:Analog1.raw
tftp-server flash:Analog2.raw
tftp-server flash:AreYouThere.raw
tftp-server flash:AreYouThereF.raw
tftp-server flash:Bass.raw
tftp-server flash:CME_GUI_README.TXT
tftp-server flash:CallBack.raw
tftp-server flash:CampusNight.png
tftp-server flash:Chime.raw
tftp-server flash:CiscoFountain.png
tftp-server flash:CiscoLogo.gif
tftp-server flash:CiscoLogo.png
tftp-server flash:Classic1.raw
tftp-server flash:Classic2.raw
tftp-server flash:ClockShop.raw
tftp-server flash:Delete.gif
tftp-server flash:Desktops/320x212x12/List.xml
tftp-server flash:Desktops/320x212x16/List.xml
tftp-server flash:Desktops/320x216x16/List.xml
tftp-server flash:DistinctiveRingList.xml
tftp-server flash:Drums1.raw
tftp-server flash:Drums2.raw
tftp-server flash:FilmScore.raw
tftp-server flash:Fountain.png
tftp-server flash:HarpSynth.raw
tftp-server flash:Jamaica.raw
tftp-server flash:KotoEffect.raw
tftp-server flash:MorroRock.png
tftp-server flash:MusicBox.raw
tftp-server flash:NantucketFlowers.png
tftp-server flash:Piano1.raw
tftp-server flash:Piano2.raw
tftp-server flash:Plus.gif
tftp-server flash:Pop.raw
tftp-server flash:Pulse1.raw
tftp-server flash:Ring1.raw
tftp-server flash:Ring2.raw
tftp-server flash:Ring3.raw
tftp-server flash:Ring4.raw
tftp-server flash:Ring5.raw
tftp-server flash:Ring6.raw
tftp-server flash:Ring7.raw
tftp-server flash:RingList.xml
tftp-server flash:Sax1.raw
tftp-server flash:Sax2.raw
tftp-server flash:TN-CampusNight.png
tftp-server flash:TN-CiscoFountain.png
tftp-server flash:TN-CiscoLogo.png
tftp-server flash:TN-Fountain.png
tftp-server flash:TN-MorroRock.png
tftp-server flash:TN-NantucketFlowers.png
tftp-server flash:Tab.gif
tftp-server flash:Vibe.raw
tftp-server flash:admin_user.html
tftp-server flash:admin_user.js
tftp-server flash:dom.js
tftp-server flash:downarrow.gif
tftp-server flash:en_bacd_allagentsbusy.au
tftp-server flash:en_bacd_disconnect.au
tftp-server flash:en_bacd_enter_dest.au
tftp-server flash:en_bacd_invalidoption.au
tftp-server flash:en_bacd_music_on_hold.au
tftp-server flash:en_bacd_options_menu.au
tftp-server flash:en_bacd_welcome.au
tftp-server flash:en_bacd_xferto_operator.au
tftp-server flash:ephone_admin.html
tftp-server flash:logohome.gif
tftp-server flash:music-on-hold.au
tftp-server flash:normal_user.html
tftp-server flash:normal_user.js
tftp-server flash:sn_handshake.html
tftp-server flash:sxiconad.gif
tftp-server flash:telephony_service.html
tftp-server flash:uparrow.gif
tftp-server flash:vlan.dat
tftp-server flash:xml-test.html
tftp-server flash:xml.template
tftp-server flash:Core_2.cfg
tftp-server flash:ringtones/RingList.xml
tftp-server flash:ringtones/DistinctiveRingList.xml
Should that be corrected?
-Brian
I made those changes and I also tried to clean up my cionfig a bit. My tftp-server enteries now look as follows:
tftp-server flash:desktops/Fountain.png
tftp-server flash:desktops/MorroRock.png
tftp-server flash:desktops/NantucketFlowers.png
tftp-server flash:desktops/TN-CampusNight.png
tftp-server flash:desktops/TN-CiscoLogo.png
tftp-server flash:desktops/TN-Fountain.png
tftp-server flash:desktops/TN-MorroRock.png
tftp-server flash:desktops/TN-NantucketFlowers.png
tftp-server flash:desktops/TN-CiscoFountain.png
tftp-server flash:/phones/7940_7960/P00308000500.sbn
tftp-server flash:/phones/7940_7960/P00308000500.bin
tftp-server flash:/phones/7940_7960/P00308000500.sb2
tftp-server flash:/phones/7940_7960/P00308000500.loads
tftp-server flash:/bacdprompts/en_bacd_allagentsbusy.au
tftp-server flash:/bacdprompts/en_bacd_disconnect.au
tftp-server flash:/bacdprompts/en_bacd_enter_dest.au
tftp-server flash:/bacdprompts/en_bacd_invalidoption.au
tftp-server flash:/bacdprompts/en_bacd_music_on_hold.au
tftp-server flash:/bacdprompts/en_bacd_options_menu.au
tftp-server flash:/bacdprompts/en_bacd_welcome.au
tftp-server flash:/bacdprompts/en_bacd_xferto_operator.au
tftp-server flash:/autoattendant/AA_SBCS_v01.aef
tftp-server flash:/autoattendant/AA_transfer.aef
tftp-server flash:/ringtones/Drums1.raw
tftp-server flash:/ringtones/Drums2.raw
tftp-server flash:/ringtones/FilmScore.raw
tftp-server flash:/ringtones/HarpSynth.raw
tftp-server flash:/ringtones/Jamaica.raw
tftp-server flash:/ringtones/KotoEffect.raw
tftp-server flash:/ringtones/MusicBox.raw
tftp-server flash:/ringtones/Piano2.raw
tftp-server flash:/ringtones/Pop.raw
tftp-server flash:/ringtones/Pulse1.raw
tftp-server flash:/ringtones/Ring1.raw
tftp-server flash:/ringtones/Ring2.raw
tftp-server flash:/ringtones/Ring3.raw
tftp-server flash:/ringtones/Ring4.raw
tftp-server flash:/ringtones/Ring5.raw
tftp-server flash:/ringtones/Ring6.raw
tftp-server flash:/ringtones/Ring7.raw
tftp-server flash:/ringtones/Sax1.raw
tftp-server flash:/ringtones/Sax2.raw
tftp-server flash:/ringtones/Vibe.raw
tftp-server flash:/ringtones/RingList.xml
tftp-server flash:/ringtones/DistinctiveRingList.xml
Now it seems to tell me much quicker this time that RingList & DistinciveRingList files cannot be found.
Is there a way to tell the phones where exactly to look for those files?
Brian
Figured it out.
Needed to add alias to all the ring tone entries in TFTP-SERVER.
Brian
Brian,
Thanks for letting us know how you solved it.
Cisco Moderation Team
