03-11-2010 02:09 PM - edited 03-21-2019 02:17 AM
Here is what I would like to do. Setup outbound caller ID for specific extensions. Example x4400 has inbound DID of xxx-xxx-4400 I would like for when this phone makes an outside call the receiving party sees xxx-xxx-4400 on his or her phone NOT or main number like is now. I do not see where I can change that in CCA.
I persnally know little about CLI. If this needs to be done through CLI then maybe some info on making these changes would be nice. I would enjoy learning CLI anyhow.
03-11-2010 03:27 PM
CCA 2.2.2 (but it was there in 2.2.1 too I think). Telephony:Outgoing Dial Plan, second tab, bottom. CLick Help.
This may be possible I think.
If its a SIP trunk, this may not work, since changing this will adjust the FROM header in the SIP invite and the S.P. may reject unknown From header values...
Steve
05-24-2010 04:32 PM
Sorry for the delay on responding. I think I have something incorrect. I am running CCA2.2.4 currently.
Outgoing dialing plan I am using north american 7-digit
PSTN Trunk Group is T!/E1 - longest idle Members are on the T1.
Now when I click apply I get an error at the bottom of the window "Caller ID Main PSTN is Required" Ok I am lost on that one.
Now my Caller ID tab. Says the following. "Caller ID Configuration is not needed. FXO trunks handle Caller ID Automatically" I have disabled the FXO ports also.
Steve, I know were you are talking about the options you posted earlier. I have another UC520 in another branch and I see were I can change the OUtbound Caller ID on an Extension level.
I think I am missing something in the config here on the machine.
