Outpulsed Digits from the telco switch
holguie81
In preparation for a UC540 deployment with PRI card the telco asked two questions that we were not sure about and wanted to see if anyone could shed some light one these questions
3. What is the number of Outpulsed Digits (digits we send to you from our Switch)?
4. Are there any unacceptable Lead Digits in the Outpulsed Digits?
Thank you in advance.
mcasimirc63
Level 4
Level 4
The number of accepted digits you accept depends on your dial plan.  Outpulsed digits are the amount of digits the telco sends to you so that your gateway can process and route the call.  If you use four digit extensions then you should accept four.
mcasimirc63
Level 4
Level 4
Thanks for confirming this.
