Paging through all phones and external paging system simultaneously
ppatel101
I have recently installed UC320W with 2 FXO and 1 FXS line using Key system. I have used the Line out to connect the Paging.  The issue is that the customer likes to have all their phones ring and paging on the external paging simultaneously when he gets a call on any line. Has anyone got a workable solution?  I saw an old discussion on this subject for UC560, but that discussion is not yet answered.
Thanks for a quick resolution.
5 Replies 5
ppatel101
This is the previous discussion for UC560 on the same subject.
https://supportforums.cisco.com/message/3382950#3382950
Hi Pramod,
The UC320W's paging feature will work thru connected SPA IP phones and the External Paging System. It does not however page thru the analog phone on the FXS port.
You can set this thru the Call Routing -> Call Paging;  simply select all the IP phones on the customer site, and check the box to "Include External Paging".
Hope this helps,
Julio
(Click on image to enlarge)
I'm considering propsing a Bogen single zone telephone interface to work with the UC320W for paging on overhead speakers via speaking into the SPA504s.  Have you heard of any other customers successfully using Bogen with the 320W?  Thanks
http://www.bogen.com/products/selfamplified/#ceiling
Kathy, as I mentioned in your other thread on this topic I'd give Bogen a call.  Tell them what equipment of theirs you're working with and I'm sure they can tell you what configuration is required on the UTI-1 to get it working with the UC320W.
