09-16-2011 10:12 AM - edited 03-21-2019 09:38 AM
Have just unpacked and connected my new PAP2-NA. I have verified that DHCP is enabled and retrieved the IP address. But my browser won't connect to the ATA and I can't see it on the network. I have manually entered its IP address in my firewall in case that was the problem. I have unplugged and replugged it. I have rebooted it. The ethernet LED is blinking green. Any suggestions as to what I should try next?
09-16-2011 11:31 AM
Try to reset it to factory default. Connect a phone into line1 and use this code:
73738#
1#
If you try to PING the PAP, do you get a response?
09-17-2011 02:28 AM
Thank you for the suggestions. I've now tracked down the problem to a dodgy bit of ethernet cable with an intermittent fault in it.
