PAP2T-EU
Hello All!
I use CM 6.1.
I try connect PAP2T-EU to CM...
I have not expirience work with Linksys so I can not configure Linksys corret...
Can anybodu provide step by step configuration?
Thank you very much!!!
5 Replies 5
Patrick Born
Hi chernyakov,
Refer to the ATA Admin Guide for registration documentation. https://www.myciscocommunity.com/docs/DOC-2149
Here's a direct link: http://www.cisco.com/en/US/docs/voice_ip_comm/csbpvga/ata/administration/guide/ATA_AG_v3_NC-WEB.pdf
You should perform the following tasks, in order, so that you start from a known point:
1. Factory reset the device [page 226 in the "How do I access the ATA device if I forget my password?" section]
2. Upgrade to the latest firmware
3. Configure the device to register to your CM [starting on page 39 and then on to page 42]
Patrick
Hello Patrick!
Thank you very much for useful links...
But I have some trouble...
Sopftware version of my device is 3.1.15(LS)
Is this latest version?
Where can I download new version?
Hi chernyakov,
The current version of firmware is available from http://cisco.com/smallbusinessand then search on pap2t.
You need to log in as a guest, registered user, or partner in order to download firmware.
Patrick
Hello, Patrick!
Thank you very much for useful links, but we have some troubles else...
When we dial some number, dialing process last 10 seconds, but we need it last max 3 seconds... How we can configure this parameter?
Hi Ordenador,
You can modify the Interdigit Long Timer from 10 to a shorter time in seconds:
PAP2T web-ui > Regional > Control Timer Values > Interdigit Long Timer: 3
More information in the Admin Guide:
Patrick
