pap2t password problem
goodboss1
using PAP2T. I forgot the password.
I can not enter the ip address of the interface at the moment. but it also does not try the following way. not start again.
IVR 73738#
Passwords I tried:
* 78196365
* 50274537
* 7756112
* 8995523
* 5465866
in the above figure does not happen. does not work and start again.
What is the re-start the PAP2T and a new password or default password.
I can not use the device in any way. Waiting for your help.
forgotten password you want to remove. in the above figure does not happen. does not work and start again.
nseto
Level 6
Level 6
Unfortunately, if you lose the admin pw, you can't factory reset the unit.
If the unit is from a service provider, they would be able to re-provision the unit for you.
Now this device is to be taken away.
Do not have no way of it.
I can not enter the interface screen. Does not enter the ip address is ip from DHCP. I want to restart but it wants the password.
Waiting, please consult with the experts on this issue. cisco of the products we buy, we trust. necessarily must be a way
Waiting, pleaseconsult with the experts on this issue.cisco of the products we buy, wetrust.necessarily must be a way
