Phone restarts when calling
Hi, since the last week my spa 303 after establishing a call (3-7 seconds in the call) the phone restarts it goes to the blank screen and boot up again(it happens on phone number and extensions numbers) i catch logs and this shows up, hope anyone can help me, thanks in advance.
2023/03/03 14:33:21.513             192.168.1.96      Informat..   local0             [1:19960] <<45.79.34.90:49999
2023/03/03 14:33:21.521             192.168.1.96      Debug         local0             SIP/2.0 200 OKVia: SIP/2.0/UDP 192.168.1.96:19960;branch=z9hG4bK-80d372f9:received=187.199.31.178xport=19960From: "1400" <sip:1400@pbx9262.pbxhosting.c...
2023/03/03 14:33:21.521             192.168.1.96      Informat..           local0
2023/03/03 14:33:21.522             192.168.1.96      Informat... local0
2023/03/03 14:33:21.523             192.168.1.96      Debug  llocal2    ResplooseMatch
2023/03/03 14:33:21.526             192.168.1.96      Informat..           local°     [1:19960]->45.79.34.90:49999[611)
2023/03/03 14:33:21.526             192.168.1.96      Informat..           local0    [1:19960]->45.79.34.90:49999[611)
2023/03/03 14:33:21.527             192.168.1.96      Debug  local°                     ACK sip:0014128372565©45.79.34.90:49999 SIP/2.0Via: SIP/2.0/UDP 192.168.1.96:19960;branch=z9hG4bK-6aa6013fFrom: "1400" <sip:1400@pbx9262.pbxhosting.co...
2023/03/03 14:33:21.527             192.168.1.96      Informat... local°
2023/03/03 14:33:21.528             192.168.1.96      Informat..           local0
2023/03/03 14:34:14.291             192.168.1.96      Debug  local3                    IDBG: LS, 4b0-5f0
2023/03/03 14:34:14.329             192.168.1.96      Debug  local3                    IDBG: SOK
2023/03/03 14:34:14.330             192.168.1.96      Debug  local3                    IDBG: st-0
2023/03/03 14:34:14.349             192.168.1.96      Debug  local2                    Resolving pbx9262.pbxhosting.com.mx
2023/03/03 14:34:14.349             192.168.1.96      Debug  local3                    [SIP_getlpBySrvHostEx] query pbx9262.pbxhosting.com.mx
2023/03/03 14:34:14.359             192.168.1.96      Debug  local2                    Resolving pbx9262.pbxhosting.com.mx
2023/03/03 14:34:14.359             192.168.1.96      Debug  local0                    <Embedded Msg>:save param: 519 = 255 519
2023/03/03 14:34:14.359             192.168.1.96      Debug  local3                    [SIP_getlpBySrvHostEx] gutty pbx9262.pbxhosting.com.mx
2023/03/03 14:34:14.360             192.168.1.96      Debug  local3                    [SIP_getlpBySrvHostEx] gutty pbx9262.pbxhosting.com.mx
2023/03/03 14:34:14.370             192.168.1.96      Debug  local3                    [BKpic]Loading blank background image
2023/03/03 14:34:14.708             192.168.1.96      Debug  local2                    skt e 2 -1
2023/03/03 14:34:14.709             192.168.1.96      Informat..local0               +++ need tftp addr..
2023/03/03 14:34:14.743             192.168.1.96      Error      kernel                   PGSK: chkdnd in Shared Held key list is not defined
2023/03/03 14:...                            192.168.1.96      Error    kernel                   PGSK: chkdnd in Progressing key list is not defined
2023/03/03 14:...                            192.168.1.96     Error                     kernel   PGSK: chkcfwd in Progressing key list is not defined
2023/03/03 14:...                            192.168.1.96     Error                     kernel   PGSK: chkdnd in Idle key list is not defined
2023/03/03 14:...                            192.168.1.96     Error                     kernel   PGSK: chkcfwd in Idle key list is not defined
2023/03/03 14:...                            192.168.1.96     Error                     kernel   PGSK: chkcfwd in Releasing key list is not defined
2023/03/03 14:...                            192.168.1.96     Error                     Kernel   PGSK: chkdnd in Releasing key list is not defined
2023/03/03 14:...                            192.168.1.96     Error                     kernel   PGSK: chkdnd in Releasing key list is not defined
2023/03/03 14:...                            192.168.1.96     Error                      kernel GSK: chkcfwd in Hold key list is not defined
2023/03/03 14:...                            192.168.1.96     Error                      kernel PGSK: chkcfwd in Hold key list is not defined
2023/03/03 14:...                            192.168.1.96     Error                     kernel   PGSK: chkdnd in Hold key list is not defined
2023/03/03 14:...                            192.168.1.96     Error                      kernel PGSK: chkcfwd in Shared Active key list is not defined
2023/03/03 14:...                            192.168.1.96     Error                     kernel   PGSK: chkdnd in Shared Active key list is not defined
2023/03/03 14:...                            192.168.1.96    Error                      kernel  PGSK:chkdnd in Shared Active key list is not defined
2023/03/03 14:...                            192.168.1.96     Error                     kernel   PGSK:    chkcfwd in Shared Held key list is not defined
2023/03/03 14:...                            192.168.1.96     Error                     Kernel   PGSK: chkdnd in Shared Held key list is not defined
2023/03/03 14:34:14.744             192.168.1.96      Informat..           local°[PHONEAPP]: PHN_eventProc msg=(WM_SYS_REDRAW_PHONE) par=(0) par2=(0x0)
2023/03/03 14:34:14.749             192.168.1.96      Informat..           local°[0]Reg Addr Change(0) 0:0->2d4f225a:49999
2023/03/03 14:34:14.753             192.168.1.96      Informat..           local°[0:19965]- >45.79.34.90:49999(524)
2023/03/03 14:34:14.753             192.168.1.96      Debug  local°                     REGISTER sip:pbx9262.pbxhosting.com.mx:49999 SIP/2.0Via: SIP/2.0/LIDP 192.168.1.96:19965;branch=z9hG4bK-ded86d43From: "1200   <sip:1200©pbx9262.pbxhost...
2023/03/03 14:34:14.754             192.168.1.96      Informat... local°
2023/03/03 14:34:14.755             192.168.1.96      Informat... local°              [1]Reg Addr Change(0) 0:0->2d4f225a:49999
2023/03/03 14:34:14.756             192.168.1.96      Informat... local°              [1]Reg Addr Change(0) 0:0->2d4f225a:49999
2023/03/03 14:34:14.760             192.168.1.96      Informat... local°              [1:19960]- >45.79.34.90:49999(523)
2023/03/03 14:34:14.760             192.168.1.96      Informat..           local°     [1:19960]- >45.79.34.90:49999(523)
2023/03/03 14:34:14.760             192.168.1.96      Debug  local°                     REGISTER sip:pbx9262.pbxhosting.com.mx:49999 SIP/2.0Via: SIP/2.0/UDP 192.168.1.96:19960;branch=z9hG4bK-88287dba From: "1400" <sip:1400@pbx9262.pbxhosti...
2023/03/03 14:34:14.761             192.168.1.96      Informat..           local°
2023/03/03 14:34:14.763             192.168.1.96      Informat... local°
2023/03/03 14:34:14.763             192.168.1.96      Informat... local°              [2]Reg Addr Change(0) 0:0->2d4f225a:49999
2023/03/03 14:34:14.826             192.168.1.96      Informat... local°              [0:19965] <<45.79.34.90:49999
2023/03/03 14:34:14.826             192.168.1.96      Debug  local°                     SIP/2.0401 Unauthorized Via: SIP/2.0/UDP 192.168.1.96:19965branch=z9hG4bK-ded86d43received=187.199.31.178rport=19965From: "1200" <sip:1200©pbx9262.p...
2023/03/03 14:34:14.826             192.168.1.96      Informat..           local°
2023/03/03 14:34:14.827             192.168.1.96      Informat..           local°
2023/03/03 14:34:14.829             192.168.1.96      Informat..           local°     [1:19960] <<45.79.34.90:49999
0 Replies 0
