SPA504G Ringtone
briangroper
Hi Forum
Newbie here.
Is there an easy way to make the SPA504G sound like a "normal" phone for an incoming call ?
I'm looking for the ringing sound that a regular phone (connected to old-fashioned telco) makes for an incoming call.
In Australia, thats two short bursts of buzz or purring sound, repeated after a longer pause.
I've tried each of the installed default ringtones, but they're all fairly unappealing, (and thats being polite).
TIA's for any tips and clues.
6 Replies 6
you can create your own!
Creating and Uploading Ring Tones Using the Ring Tone
Utility (Cisco SPA30X and Cisco SPA50XG only)
To convert a file for use as a ring tone, use the Ring Tone Utility, available at:
https://supportforums.cisco.com/docs/DOC-9944
You must have a .wav file less than 8 seconds in length saved to your computer.
You can also use a sound editor to create the file with the following restrictions:
16-bit PCM mono
8000 samples per second
less than 6000 ms in length
To create a ring tone and upload it to a phone:
STEP 1
Open the Ring Tone Utility.
STEP 2
Enter the IP address of the phone.
STEP 3
Click Browse and navigate to the directory on your computer where the source
.wav file is stored. Select the wav file and click Open.
STEP 4
Click Load Source File.
STEP 5
Enter a name for the ring tone. This name will appear in the display on the phone.
You choose the file name later.
STEP 6
Enter the target. You can have up to two customized ring tones uploaded to the
phone.
STEP 7
(Optional) Click Preview to preview the ring tone. Click Options to change the start
or end positions, or to squeeze or stretch the audio.
STEP 8
Click Upload to Phone to upload the ring tone to the phone. Click OK when the
success status message appears.
STEP 9
Close the open Ring Tone Utility windows.
To create a ring tone and save it to a file:
STEP 1
STEP 2
Enter the IP address of the user’s phone or press Skip to create the ring tone and
save it as a file.
STEP 3
STEP 4
Click Load.
STEP 5
Enter a name for the ring tone. This name will appear in the phone display. You
STEP 6
STEP 7
Click Save As to save the file to your computer. Enter the file name and press Save.
STEP 8
To delete a ring tone from a phone:
STEP 1
STEP 2
STEP 3
Click the Delete button next to the ring tone you want to delete.
STEP 4
Click OK.
STEP 5
Assigning a Ring Tone to an Extension
STEP 1
Log in to the configuration utility.
STEP 2
Click Admin Login and advanced.
STEP 3
Click the Ext tab.
STEP 4
Under Call Feature Settings, in the Default Ring field, choose from the following:
No Ring
1 through 10
User 1
User 2
STEP 5
Click Submit All Changes.
briangroper
Thanks for details.
I click-clack at your link, but it just gives :
Unauthorized
Please login to access this site (top right of this screen).  If your  login is unsuccessful, your Cisco.com login does not have the authority  level to access this site.
You may need to ask your partner for it.
It’s a partner tool hence protected where its posted.
In the interim, we've sent this request up the chain to determine whether or not it should be made avail to all.
Sorry, but I don't have any "partner" with a tool.  Firmly committed to remaining "single".
I've bought a single SPA504G to make some testing and evaluation before buying a bunch more for my small business.
Was hoping to just press a few buttons to make the ring sound suitable and sensible.
And quite surprised such a simple feature seems so complicated.
TIA's
BTW. Using Firmware Version: 7.4.8a
try this link:   https://supportforums.cisco.com/docs/DOC-9944
hope it works for you -
Good Luck
kingfredmu
Hello . you can update the best and most attractive ringtones at Suonerie Gratis
