07-09-2012 07:06 PM - edited 03-21-2019 06:01 AM
Hi friends,
How can i pickup a call ringing another extension, using the SPA501G?
TKS
Solved! Go to Solution.
07-12-2012 11:42 AM
Hello Thiago Cella,
you cannot add any phone buttons on this phone to configure a pickup function in combination with a UC320W.
Friedrich
08-27-2012 10:11 AM
Thiago,
The pickup function call flow uses the softkey dial which is not present on the spa501. Thus the pickup function *36 is disabled on SPA501 phones.
Try configuring line monitor feature on a spare SPA501 phone button for the users extension to pickup. Then the end user can just press the flashing button on the SPA501 to answer the incoming call.
From UC320W configuration utility
Phone Buttons -> Select SPA501 phone -> Configure unused button -> Line Monitor -> select extension to monitor
Randy
07-12-2012 11:42 AM
Hello Thiago Cella,
Friedrich
07-18-2012 06:24 PM
Tks man!
to work around i configured a shared line to all extensions, so when the rings, anyone can pickup the call.
Tks
08-27-2012 08:23 AM
People,
Sorry to "resurrect" this post, but the customer is complaining that all SPA501G are ringing in same time. Is there another way to users pickup calls ?
08-27-2012 10:11 AM
Thiago,
Randy
09-02-2012 06:57 AM
Tks Randall,
This way the calls can be pickup, and not ringing on same time.
