02-23-2009
11:37 PM
- last edited on
03-25-2019
10:33 PM
by
ciscomoderator
My carrier is sending me numbers without the leading area code digits.
This is causing issues when I dial out & also when I use applications like Callconnector etc
How do I ensure that all my missed calls have the full number including area code.
Luke
02-24-2009 01:43 AM
Well, if the carrier is really sending you all calls without the area code, then there is nothing you can do. How do you distinguish between calls coming from the same phone number in different states (We are talking about the calling number here, aren't we)?
However, this does seem a bit unlikely. It seems more likely that the carrier is not presenting the full number when the calling number's area code matches your area code. If so, then we can create or modify a translation rule to cover this situation if necessary.
Can you confirm whether this behaviour occurs on *all* calls, or just those from the same area code?
Cheers,
Dave.
02-24-2009 02:43 PM
Thanks Mysterious Stranger.
I'm looking for the leading 0 on the area code / mobile number.
I can do this with a voice translation profile but looking to see if theres any CCA or easier way.
45778: .Feb 24 06:56:26.830: ISDN BR0/3/1 Q931: RX <- SETUP pd = 8 callref = 0x1F
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x81
Preferred, B1
Calling Party Number i = 0x2181, '413000000'
Plan:ISDN, Type:National
Called Party Number i = 0xC1, '82380000'
Plan:ISDN, Type:Subscriber(local)
High Layer Compat i = 0x9181
02-24-2009 04:37 PM
This feature is not supported in CCA (yet). You have to create a voice translation profile for incoming dial-peer.
Eivind
02-25-2009 06:57 PM
Luke - the call connector has it's own settings that may not be playing nicely here.. make sure your settings under your modem for local area codes and 10 digit dialing are all set. Call Connector uses those settings and not the CME settings. Like everyone else says here, you need to set up a Translation profile in CME for 10 digit dialing. I have done this at a few install sites and it works well. The UC500 is a very powerful unit, the only real way to configure it is using the CLI at this point. The configuration assisant is helpful at the start and saves you a few hours of configurations but to really make this product shine you have to get your hands dirty with CLI.
03-29-2009 10:47 PM
FYI Mission Accomplished I have 0 added to the incoming calls.
Here is the config I used for reference
Note: Only add the lines in bold ... your dial peers should already exist.
Luke
voice translation profile ADD_ZERO
translate calling 2345
voice translation-rule 2345
rule 1 // /0\1/
dial-peer voice 3000 pots
translation-profile incoming ADD_ZERO
incoming called-number 8640050[1-7]
direct-inward-dial
no sip-register
no digit-strip
port 0/1/0
dial-peer voice 3001 pots
direct-inward-dial
no sip-register
no digit-strip
port 0/1/1
dial-peer voice 3002 pots
direct-inward-dial
no sip-register
no digit-strip
port 0/3/0
dial-peer voice 3003 pots
direct-inward-dial
no sip-register
no digit-strip
port 0/3/1
