HelloThis is really a probably a daft question but how to you enable the night-service manually from a night-service phone. If it just a point of pressing * then the night-service code?Many ThanksStuart
I am trying to install the SPA9000 with an SPA400 unit. I have 2 phones 1xSPA962 and 1xSPA942. I am running a mac with virtual PC ruinning XP. The setup wizard is not recognizing either the SPA9000 or the SPA400 on the network. I have an RVL200 Links...
Hi,the SPA9XX with the SPA9000 can have a remote station?i mean to take away your SPA9XX to vacations and plug it into hotels network and there you go, you have your office extencion in the hotels room.and how to doit?? and what i need??Best regards.
I am having an issue with our MeetMe conferencing configuration.I configured MeetMe using the supplied document. We are using the same extension number for MeetMe as the document uses, 1500. Our internal extensions however are all 3 digit. The only 4...
I have an install with SPA9000 and SPA400 with 2 analog phone lines. Very often the outgoing telephone lines go dead. There would not be any dial tone. This happens very frequently and I suspect it has to do with the line disconnect signal. How d...
What is the best free ware software to use to size yoru image to png to fit onto the ip phone? I am really hit and miss with the sizing use vista, the fiels are loaded on the flash, the tn shows up in the image background on the phone, but not all of...
Does anyone know if there's a way to run CGI or PHP scripting on a UC500.I have made some nice tools for the UC500 but have to run them on a different device. I want them to run on the UC500. Is there a way to run it as a webserver?And something like...
How about a GSM Gateway form Cisco.I got a lot of client that have the UC520 that want to use a GSM Gateway there are 3rd party product, but they want a cisco.. Is there anything out there? Or in the nearby future?Or is there a recommend Gateway by C...
we just purchased an VWIC2-1MFT-T1/E1 card trying to look for any guies that would describehow to install it and configure it.We will be setting up a T1 ISDN PRI connection with our Avaya PBX.we have an Idea of the configuration on the Avaya PBX side...
Hi all,i'm quite new to cisco voice products and i need some help to configure correctly my new uc..if i connect the ip phone with the default configuration it can't get ip via DHCP on uc and remain in "registering" phase..Where can i found some docs...
HelloI've recently installed a UC520 and the last thing I need to do it a night service call forward.Is there a way where you can activate any on of four call forwards from the phone using a code, all the phones recieve calls from one number which i...
Hi,I have a SPA941 running with the latest firmware 5.1.8. DST is not working. Time is one hour behind. This was also a problem with the SPA-9x2 phones before and was corrected with a new firmware. Is there a fix for this?Regards,Ryan
Hi,Is there a way to configure Cisco 7937 Conference phone to work with the UC520? I've installed the Software Pack UC520-4.2.9 and the other phones (7960 and 521SG) are working except the 7937.Thanks in advance.
