Problem with CFW to an Extension (HG) on another UC500 via voip dial-peer
Eric.Hedler
Hi there,
this is my first post, so please be lenient with me
If got the following constellation running and I`ve got a problem at present, which I don`t really understand. I just wanted to add another BRI Interface to get two more channels for calls via PSTN. So I changed some condiguration parameters.
After these changes I had to find out, that a call forwarding betwen two UC500 (in different branches) from a DN to a hunt group is not possible anymore. I just hear nothing. No ringing, no noise...absolutely nothing.
Any Ideas?
I rolled back to the old configuration, but the problem still exists. I did some tests to find out where the prob is, but I don`t get it (used another DN with forward all etc.). A strange thing is, that I can Call forward when busy or no answere and then, the hunt group is ringing?!
Here is the way I try to call:
BRANCH 1:                                                            BRANCH 2:
Call from "131"                     -------------->                   Calling "320"
        v
Calling "130" (HuntGroup)      <--------------                  Call Forward All
These are the dial-peers:
Branch1:
dial-peer voice 10 voip
preference 1
destination-pattern 3..
progress_ind setup enable 3
modem passthrough nse codec g711alaw
session target ipv4:172.16.101.1
incoming called-number .
voice-class codec 1
dtmf-relay h245-alphanumeric
fax rate disable
fax protocol pass-through g711alaw
no vad
Branch2:
dial-peer voice 2 voip
preference 1
destination-pattern 1..
session target ipv4:172.16.100.3
voice-class codec 1
voice-class h323 1
fax rate disable
no vad
As I mentioned before, the call forwarding when busy or no answere seems to work?! Also the call forward all to a simple DN (not to a huntgroup) is working....
What I can see from a "debug voip dialpeer inout"
281811: Dec 17 11:06:21.453: %VOICE_IEC-3-GW: H323: Internal Error (H225 invalid msg): IEC=1.1.95.5.27.0 on callID -1
281812: Dec 17 11:06:21.453: %VOICE_IEC-3-GW: H323: Internal Error (H225 invalid msg): IEC=1.1.95.5.27.0 on callID -1
281813: Dec 17 11:06:21.453: %VOICE_IEC-3-GW: H323: Internal Error (H225 invalid msg): IEC=1.1.95.5.27.0 on callID -1
281814: Dec 17 11:06:21.453: %VOICE_IEC-3-GW: H323: Internal Error (H225 invalid msg): IEC=1.1.95.5.27.0 on callID -1
Is that normal?!
I get the same Error when call forward all directs to a DN. But thats working, how I mentioned before.
Sunish Nair
Can i know what steps you have taken for resolving this issue, because my customer also getting same error message.
