problem with spa8000
alinasery62
hello everybody
i have a spa8000 and i reseted this device to default factory by interactive voice response menu,
the problem is when i try to login to the web management of device , login page appear and want username and password
i tried username:admin password:[none] , username:admin password:admin , but it doesnt work
firmware version is 5-1-10
i appreciate your help
thank you
By default, there are no passwords assigned for either the Administrator account or the User account.
Probably your reset procedure failed.
Follow this: connect an analog phone to FXS 1 port and press **** then 73738# then 1 to confirm.
Regards.
Regards.
thanks for your answer daniele
but i tried it by analog phone and heard "option successful" but
still i have same problem and i can't login to device.
thank you very much daniele
i was wrong and i connected my analog phone to FXS 8.
but this time i did by FXS 1 and it works.
thank you again
