10-02-2011 02:57 PM - edited 03-21-2019 04:45 AM
Hi all,
I have the exact same problem as described here:
https://communities.cisco.com/thread/9965
That the phone number is getting ABCD appended at the beginning.
All outgoing calls are going through a SIP trunk provider.
However, there is no solution posted to the problem - does anyone know what to do?
10-05-2011 03:45 PM
Hi Simon,
If you have a support contract on the appliances then it is strongly suggested you log a case with SBCS on this, I suspect that there is a requirement for some CLI programming to be made to get it to work properly for you. Any advice that one would give you of this forum, could pose a risk in that it might take the system out of support scope, we all need to avoid this.
Are you able to log a support case on this? If not then we can look at alternatives if need be.
Cheers,
David.
10-05-2011 03:53 PM
Good news is CCA support for SPA8800/8000 is coming in the next release of CCA 3.2
10-14-2011 02:55 AM
Hi Navin,
When is 3.2 scheduled to be released please?
Craig
