Prompt Management
jcarter
Level 4
Level 4
If a company had 10 prompts, is there an easy way for them to access the prompts using the phone management?  By easy, I mean when you are trying to find the one you want to rerecord, is there an easy way to get to prompt 9 or 10 without hitting the # key 8 or 9 times?
Steven DiStefano
I dont know of a way to go direct to a specific prompt.  I also skip through with # key.
Steve
Alternatively, you could use CCA to manipulate them individually.
Marcos
