04-23-2010 09:27 AM - edited 03-21-2019 02:29 AM
I am trying to get the PVC2300 to play nice with a UC520 (7.1.3), and I've uploaded 1.1.2.6 to the camera. I can see it via Bonjour in CCA, but when I go into the Video Monitor Setup Wizard it says: No Cisco 2300 series camera found.
I am using a unique for for the web interface and others, but how is CCA trying to find the device?
If I click Add to Community in CCA is says the device is not reachable (I'm not sure if it's doing a DNS lookup or what)
Anyway,
What do I need to be able to get this working/discoverable/communicating?
Cheers.
Bob James
04-23-2010 02:23 PM
Not blocking any ports, rtsp is default (554), my Gui is identical with the correct rtps configuration, user, extension, the works.....
By the way the GUI is soooo linksys
04-23-2010 02:32 PM
Im out of ideas
04-23-2010 03:18 PM
NEVER SAY DIE!
I got it.......
I reset the phone to factory default and reconfigured it all over. I'm guessing there is some issue with parts of configuration of the VPN and/or wireless configuration left in the phone that stopped this from working. (This phone was setup with both)
I did verify that the VPN on the phone was not active, and wireless was off as it was ethernet connected.
Anyway it works (kind of anti-climatic once I saw the video), what's the Call button for?
Thanks for trying to help, now I am back to playing with it to see what else it can do.
04-23-2010 01:35 PM
HW Version 1.0.0 is all we ever released as far as I know and thats what I have.
04-23-2010 04:48 PM
Hey bob,
Cca team responded to one of your requests. When you first create a community, you do in fact have a chance to enter the port and protocal for each device, which will be used for all subsequent connections.
So mark that one done...
Steve
04-23-2010 05:15 PM
I appreciate the feedback but that's not quite true.
You can select A port and A protocol but it's for all devices, not each one.
Check in your CCA and let me know the results.
Cheers,
Bob
04-24-2010 04:04 PM
True? Not true? When you first create a community. Try it. Not when you modify a community.
04-24-2010 05:05 PM
Tried it, same as modify, unless I am missing something, there is no way to specify a unique port for a device.....
04-26-2010 03:46 PM
Here is what we were referring to. Does this meet requirement?
04-26-2010 04:49 PM
Yes Steve,
But is this not for;
A. the seed deive, or
B. All device in the community?
What if I want all standard ports,, but a unique port for the camera because its' accessed from the Internet?
Bob
04-27-2010 11:13 AM
Bob,
You are right...In CCA, the http(s) port setting is applied to all the devices in the community. What you require is not supported in CCA. I am asking to have it added to the list of requests for new features.
Steve
04-27-2010 12:14 PM
You had me at "you are right" :D
If you're adding RFE's could your request drag and drop phone loads for Win7/IE8 in CCA?
I am many others have yet to get this working...
Bob
05-04-2010 06:43 AM
The following enhancement request was just approved to be submitted.
CSCtg49009 (CSC.sibu.dev,new,gsalguei): Ability to adjust HTTP(S) port access per device in Community connection
04-23-2010 10:54 AM
OK,
I was able to add it to the community so I assume it uses HTTP for communications over 80. It will now work with the 525.
I would like to see an enhancement wherein you are able to set the communications preferences for the camera to the port that you set it up with, including HTTPS.
I hope this helps someone else.
Cheers.
Bob
04-23-2010 11:03 AM
Bob,
You rock!
Excellent suggestion.
Perhaps under Device Properties: Device Access.
Submitting now in your good name.
Steve
