Is there a lab that demonstrates how to setup a UC520/540 behind an SA520. As well is there one that deals with third party firewalls like SonicWALL. If find most customers will have an existing firewall to work with.Thanks.
Hey guys,Is there any way to pass DHCP from an SA520 connected to the WAN port of a UC540 through to the LAN clients of the UC540? I have a client with a very strange configuration where two UC540s are sometimes going to be colocated in one area. I...
Hi CommunityI need the power consumption information for the SPA504G. The datasheet only give information for the external power supply PA-100 (5V/2Amp)
Hi All, I look after an SPA9000 + SPA400 connected to about 12 SPA942 handsets. I've not made any changes to the set-up or to the network in any way over the past 6 months and everything has been working beautifully. All of a sudden I have realised t...
Hi All,I have been experimenting on how to get a GB (English) install done from scratch without having to do a second install and get the GB language operational from the word go, some might already know this but have not provided this information on...
Hi,When I dial any local number on LINE 1, there is a delay of about 10sec before I can hear the number ringing on the other end.My analog phone is directly connected to Line 1.PSTN is not being used.Any suggestions or tweaking I can do?Thanks.
We have Cisco IP PHONE 7960 and the the sidecard 7914 (Expansion Module) hooked up to all of our phones. All phones have an overlay so we can Intercom each other.All 12 analog incoming lines are assigned to the 7914 module. It's great because we can ...
Is there a spec sheet that compares the models and its conference capabilities? I know the DSP setup in each model is different and am looking for a documentation that shows the differences.Which 48 user model can do 5 meet-me bridges in g711?
SPA 962 doesn't start. when I connect it to the switch - it gets power, but the port doesn't come up, port shows "notconnected" and the phone screen only blinks. Also 4 from 6 line buttons are amber. Can anybody tell what happened with it?Thanks in a...
Hello! I have one SPA3102 with its FXS connected to a PBX and FXO to POTS. If I send one fax from PBX side the call seems connect with remote side but after some secons the operation fails. Outgoing fax are sent from FXS to FXO directly via dialpla...
Hi,On the UC520 with both IOS 15.0(1)XA1 and XA1a, the VPN client seems to be broken? The moment I upgrade from 12.4(24)YB4 to 15.0, the VPN client can connect but there is no data transfer. If I downgrade to 12.4(24) again everything is fine. I r...
I've got a site with two analog phones in the FXS ports, and they should only be allowed to call internally and emergency. I don't see a way to configure this on the 'analog extensions' tab in CCA 2.2.2, and in the CLI i see CCA just has the ports se...
I am having issues with French_Locale, the language is not fully available on the set.eg. When I go to CME services and choose VoiceView I get weird characters appearing in words. Does anyone now which files need to be modified to fix this? Thanks
Hi Folks,Just wondering if there is a code and it's syntax for picking up calls ringing on another phone from a cordlessconnected to FXS1 or I suppose any other phone for that matter.I have found *36 in the documentation but doesn't seam to work, I w...
