04-16-2010 07:30 AM - edited 03-21-2019 02:27 AM
Is there a door access solution to use with the UC540?
04-16-2010 07:47 AM
Check out the following link and work it from there;
https://www.myciscocommunity.com/docs/DOC-1514
There may be other products from Valcom as well.
regrads Dave
04-16-2010 07:47 AM
you can use a vendor called cyberdata, they have ip based door systems that can integrate with the UC500/CCME
Best Regards,
Jerco
