Restrict access to company phone directory
Antonio Macia
Level 3
Level 3
Is it possible to restrict which extensions can access the corporative phone directory? The final purpose is to hide this directory to some extensions and allow others. Another option could be remove the softkey from the not allowed phones.
Any ideas?
Thanks in advance,
Regards.
paolo bevilacqua
Yes, it is doable. Place phones where directory has to be blocked on a seperate VLAN, theng use "ip http access-group" ACL to deny that VLAN.
Note that directory is a separate button, not a softkey, so it can't be done that way.
