10-13-2010 09:45 AM - edited 03-21-2019 03:08 AM
I have a customer that has a UC540 (FXO) and a UC5460 (PRI). The two systems are connected by a MetroE circuit. The customer wants dial 9 calls placed from the UC540 to go out the PRI on the UC560. Can this be done an dif yes how?
Solved! Go to Solution.
10-14-2010 06:39 AM
Yes, this is possible. The following is the basic config.
UC540
dial-peer voice 1 voip
destination-pattern 9T
session target ipv4:1.1.1.1 (IP address of UC560)
UC560
voice service voip
allow connections h323 to h323
incoming called-number 9T
This is assuming the dial peers pointing to the PRI on the UC560 are already in place.
Hope this helps.
Brandon
10-14-2010 06:39 AM
UC540
UC560
voice service voip
Hope this helps.
Brandon
10-20-2010 01:35 PM
Brandon,
Your suggestion works but only if a FXO trunk is not available. At this time the customer seems to be happy with the solution.
Thank you.
Doug
