SIP Notify XML-Service
FlyingDoctor_2
Has anyone got an example that works?
I have used DOC-13978 as the spec
I am not sure what to set the Content-Type header to in the Notify Message
I just get a 200OK back from the SPA525
Nothing happens and nothing in SYSLOG
Message Waiting and remote reboots work fine
12 Replies 12
Alberto Montilla
Dear sir;
Can you please provide the trace and let us know the FW version you are using on the phone?
Alberto
Should be the correct file -  A few Keepalive Notifies but last one is what you want
Tried various tweaks - to no effect
Just started to look at Device Feature Key Syncronisation as well ;->
Stuart
Sorry - 7.4.3 525G
Dear Sir;
I have escalated the issue to engineering. I'll keep you updated.
regards
Alberto
is there an update for this?
Dear Sir;
Yes, we found the inconsistency. We are working to solve it, please stay tuned.
Alberto
Is there an update on this?
can confirm does not work on 525 on 7.4.4
get back 200OK to NOTIFY and no syslog messages but XML app does not appear on Display
What is the bug number for this ?
Accoring to to Cisco Bug database there are no bugs outstanding for "Cisco Small Business Pro SPA 500 Series IP Phones"
Dear Sir;
The number is CSCtg48111. It is an enhancement and not a bug on the SPA50X phones.
For security concerns we are removing direct support on the SPA50X for the execute XML code with Notify, so behavior will be similar to what SPA525G supports today, i.e.
You can only send a URL as part of the notify-execute mode. Then the phone will grab the URL and execute the command. I'll be documenting this pretty soon, stay tuned.
Regards;
Alberto
Sorry I am confused - I am only trying to remote trigger the execution  of a previously defined application
Admin guide for 5xx phones describes NOTIFY payload as
http://xmlserver.com/event.xml"/>
What 5xx  phones is this supported in now?
for the 5xx phones that do not support this, what exactly will they support and when
thanks
Dear Sir;
We updated the document on this community to reflect the change on the behavior (starting with 7.4.4). The phone will allow receiving a XML Service URL on the SIP NOTIFY body, not the direct XML syntax. Because of security concerns, we decided to modify the old behavior.
Alberto
