SIP trunk and call forwarded extensions
davidfield
Level 3
Level 3
Hello All,
My UC520 issues continue.  After much frustration and assistance I finally got my SIP trunk running and all appeared to be well.  Calls and DDI's were working great.  I though job done. However, another issue has popped up.
One of the staff was on leave and set their phone to Call forward to another internal extension.  Now when a SIP call comes in to that extension it wont forward and the caller gets no Audio.  I've been reading and believe a Media Termination Point may be needed.  Can anyone point me to a definative explination that may help me resolve?  I have attached my config if someone has some time to tell me what I'm missing.
Thanks in advance
Dave
danplacek
Level 4
Level 4
You said "won't forward" and "caller gets no audio" -- which is it? If the forwarding fails, my best guess would be caller-id issues (UC520 is sending caller's CID, which ITSP is rejecting since it is not a number you own). If it is audio issues... that could be many things; is this UC behind a firewall or NAT?
Thanks for the reply Daniel,
The caller hears nothing.  You take the forward off and the desired internal extension gets the call and all ok.
I setup the following scenario
Currently 2805 forwarded to 2810
voice translation-rule 4
rule 1 /^02070787756/ /2805/
ephone-dn  80  octo-line
number 2805 no-reg primary
label HouseManager
description HouseMgr 2805
name House Manager
mobility
call-forward all 2810
When Call comes in on DDI 02070787756 I can see the SIP messages translation to 2810. But then it says service unavailable.
David
Try:
voice service voip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
Please rate useful posts.
Hi Daniel,
I tried your recommedation but no luck.  The impact of the above was it stopped DDI SIP calls also.
When I put it back to the original
voice service voip
ip address trusted list
ipv4 10.2.0.0 255.255.255.0
ipv4 88.215.61.0 255.255.255.0
ipv4 10.1.100.0 255.255.255.0
ipv4 10.1.37.0 255.255.255.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
fax protocol none
no fax-relay sg3-to-g3
sip
registrar server
no update-callerid
early-offer forced
midcall-signaling passthru
I get the SIP message with the diversion.
158501: 1w4d: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:2810@10.44.1.254;user=phone SIP/2.0
Max-Forwards: 69
Session-Expires: 3600;refresher=uac
Min-SE: 600
Supported: timer, 100rel
To: <2810>
P-Asserted-Identity: <07825372765>
Call-ID: 711350-3568995155-523000@MSX28.gammatelecom.com
CSeq: 1 INVITE
Allow: CANCEL, ACK, INVITE, BYE, OPTIONS, REGISTER, NOTIFY, INFO, REFER, SUBSCRIBE, PRACK, UPDATE, MESSAGE, PUBLISH
Via: SIP/2.0/UDP 88.215.61.195:5060;branch=z9hG4bK3b6aa7d01afb2845ff14f2f6c6435a22
Contact: <07825372765>
Diversion: <2805>;reason=unconditional;counter=1
Content-Type: application/sdp
Accept: application/sdp
