SIP Trunk Configuration For Voice Pulse ISP
networkwise
Level 3
Level 3
I recently purchased a Voice Pulse SIP trunk. Ive added the configuration to my UC540, the configuration was added via the command line not CCA.
I dont appear to be registering with VoicePulses specified SIP server. When I run debugs I see no attempts from the UC540 to connect to the SIP server and register. This makes me think somethng globaly is configured incorrect or there is an important statement Im missing. I do have one 3rd party SIP soft phone registered on the system and a number of Cisco handset 7900 series. Up until this point the system has been using a pots line to dial out. I havnt got to the dial plan yet I just wanted to see if I could actually register. A sample of my config is below. Ive also opened a ticket with VoicePulse to see if they have to do anything on there end to establish the connection.
Just wonderd if anyone see's something obvious that I'm missing. Appreciate any advise.
Andy
I can ping the two Voicepulse SIP servers
uc540#
uc540#ping jfk-primary.voicepulse.com
Translating "jfk-primary.voicepulse.com"...domain server (68.87.85.102) [OK]
Sending 5, 100-byte ICMP Echos to 64.61.93.190, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 56/57/60 ms
uc540#ping jfk-backup.voicepulse.com
Translating "jfk-backup.voicepulse.com"...domain server (68.87.85.102) [OK]
Sending 5, 100-byte ICMP Echos to 209.31.18.12, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 56/56/56 ms
uc540#
interface FastEthernet0/0
description $FW_OUTSIDE$
bandwidth 4000
ip address dhcp client-id FastEthernet0/0
ip access-group 104 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nbar protocol-discovery
ip nat outside
ip inspect SDM_MEDIUM out
ip virtual-reassembly
load-interval 30
duplex auto
speed auto
access-list 104 remark *****Below VoicePulse Sip ACL*************
access-list 104 permit udp host 64.61.93.190 eq 5060 any
access-list 104 permit udp host 64.61.93.190 any eq 5060
access-list 104 permit udp host 209.31.18.12 eq 5060 any
access-list 104 permit udp host 209.31.18.12 any eq 5060
access-list 104 permit udp host 192.168.10.1 eq 5060 any
access-list 104 permit udp host 192.168.10.1 any eq 5060
access-list 104 permit udp any any range 16384 32767
access-list 104 deny   ip any any log
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol none
no fax-relay sg3-to-g3
sip
  registrar server expires max 600 min 60
  localhost dns:networkwise.net
  no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
codec preference 3 g711alaw
voice class sip-profiles 1000
request ANY sdp-header Connection-Info remove
response ANY sdp-header Connection-Info remove
voice class cause-code 1
no-circuit
voice register global
mode cme
source-address 10.1.10.2 port 5060
max-dn 4
max-pool 4
create profile sync 0428016071226797
voice register dn  1
number 240
name Andy's Phone
label 240
voice register pool  1
id mac 7CC3.A1A1.EF11
number 1 dn 1
dtmf-relay rtp-nte
voice-class codec 1
username 240 password siptestpw
no vad
sip-ua
authentication username xxxxxx password 7 063637111A1A28183C4540 realm jfk-primary.voicepulse.com
authentication username xxxxxx password 7 02363C6B5D522E20751C5B realm jfk-backup.voicepulse.com
no remote-party-id
retry invite 2
retry register 10
timers connect 100
registrar dns:jfk-primary.voicepulse.com expires 60
registrar dns:jfk-backup.voicepulse.com expires 60 secondary
sip-server dns:jfk-primary.voicepulse.com
host-registrar
paolo bevilacqua
Do you have "term mon" with debugs ?
Also, you will need to register some meaningful number, not just '240'.
