04-04-2013 09:53 AM - edited 03-21-2019 07:12 AM
Hi, I configured a SIP trink in my UC500, but when I make a call this not happend, I capture a syslog, Please help.
PBX_DS#
000466: Apr 4 04:41:01.267: //-1/xxxxxxxxxxxx/RXRULE/regxrule_get_profile_from_trunkgroup_internal:
Voice port 0x8ABCEA2C dsl=-1 timeslot=0 does not belong to any trunk group
000467: Apr 4 04:41:01.271: //-1/AF88F5808076/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=
----- ccCallInfo IE subfields -----
cisco-ani=1310
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
cisco-redirectreason=0 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
000468: Apr 4 04:41:01.271: //-1/AF88F5808076/CCAPI/cc_api_call_setup_ind_common:
Interface=0x8ABCEA2C, Call Info(
Calling Number=1310,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Incoming Dial-peer=20006, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
000469: Apr 4 04:41:01.271: //-1/AF88F5808076/CCAPI/ccCheckClipClir:
In: Calling Number=1310(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
000470: Apr 4 04:41:01.271: //-1/AF88F5808076/CCAPI/ccCheckClipClir:
Out: Calling Number=1310(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
000471: Apr 4 04:41:01.271: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000472: Apr 4 04:41:01.271: :cc_get_feature_vsa malloc success
000473: Apr 4 04:41:01.271: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000474: Apr 4 04:41:01.271: cc_get_feature_vsa count is 3
000475: Apr 4 04:41:01.271: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000476: Apr 4 04:41:01.271: :FEATURE_VSA attributes are: feature_name:0,feature_time:2310325080,feature_id:33
000477: Apr 4 04:41:01.271: //51/AF88F5808076/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=1310(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown))
000478: Apr 4 04:41:01.271: //-1/AF88F5808076/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x8AF05288; count=1
000479: Apr 4 04:41:01.271: //-1/AF88F5808076/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x89298B54
000480: Apr 4 04:41:01.275: //51/AF88F5808076/CCAPI/cc_process_call_setup_ind:
Event=0x88704718
000481: Apr 4 04:41:01.275: //51/AF88F5808076/CCAPI/ccCallSetContext:
Context=0x8AD04A50
000482: Apr 4 04:41:01.275: //51/AF88F5808076/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 51 with tag 20006 to app "_ManagedAppProcess_Default"
000483: Apr 4 04:41:01.275: //-1/AF88F5808076/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x8AF05288; count=1
000484: Apr 4 04:41:01.275: //51/AF88F5808076/CCAPI/ccCallSetupAck:
Call Id=51
000485: Apr 4 04:41:01.275: //51/AF88F5808076/CCAPI/cc_api_set_transfer_info:
Transfer Number=, Transfer Reason=0x0
000486: Apr 4 04:41:01.275: //51/AF88F5808076/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=TRUE, Tone=Dial Tone,
Tone Direction=Network, Params=0x0, Call Id=51
000487: Apr 4 04:41:01.275: //51/AF88F5808076/CCAPI/ccSetDigitTimeouts:
Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
000488: Apr 4 04:41:01.275: //51/AF88F5808076/CCAPI/ccSetDigitTimeouts:
Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
000489: Apr 4 04:41:01.279: //51/AF88F5808076/CCAPI/ccCallReportDigits:
(callID=0x33, digit_event=0x1, enable=TRUE, consume=FALSE)
000490: Apr 4 04:41:01.279: //51/AF88F5808076/CCAPI/ccCallReportDigits:
Enabled=TRUE, Call Id=51
000491: Apr 4 04:41:01.279: //51/AF88F5808076/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x8ABCEA2C, callID=0x33, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
000492: Apr 4 04:41:01.279: //51/AF88F5808076/CCAPI/cc_api_call_report_digits_done:
Enabled=TRUE, Disposition=0x0, Interface=0x8ABCEA2C, Call Id=51
000493: Apr 4 04:41:01.279: //51/AF88F5808076/CCAPI/cc_api_call_report_digits_done:
Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=5000(ms))
000494: Apr 4 04:41:02.991: //51/AF88F5808076/CCAPI/cc_api_call_digit_begin:
Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Source Call Id=51, Digit=9, DigitBeginFlags=0x0,
Rtp Timestamp=0x260A48, Rtp Expiration=0x0
000495: Apr 4 04:41:02.991: //51/AF88F5808076/CCAPI/cc_api_call_digit_end:
Source Call Id=51, Digit=9, Duration=100,
Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
000496: Apr 4 04:41:02.991: //51/AF88F5808076/CCAPI/cc_api_call_digit_end:
Call Entry(Handoff Depth=0)
000497: Apr 4 04:41:05.239: //51/AF88F5808076/CCAPI/cc_api_call_digit_begin:
Source Call Id=51, Digit=1, DigitBeginFlags=0x0,
Rtp Timestamp=0x268748, Rtp Expiration=0x0
000498: Apr 4 04:41:05.239: //51/AF88F5808076/CCAPI/cc_api_call_digit_end:
Source Call Id=51, Digit=1, Duration=100,
000499: Apr 4 04:41:05.239: //51/AF88F5808076/CCAPI/cc_api_call_digit_end:
000500: Apr 4 04:41:05.779: //51/AF88F5808076/CCAPI/cc_api_call_digit_begin:
Source Call Id=51, Digit=0, DigitBeginFlags=0x0,
Rtp Timestamp=0x270448, Rtp Expiration=0x0
000501: Apr 4 04:41:05.779: //51/AF88F5808076/CCAPI/cc_api_call_digit_end:
Source Call Id=51, Digit=0, Duration=100,
000502: Apr 4 04:41:05.779: //51/AF88F5808076/CCAPI/cc_api_call_digit_end:
000503: Apr 4 04:41:06.067: //51/AF88F5808076/CCAPI/cc_api_call_digit_begin:
Rtp Timestamp=0x278148, Rtp Expiration=0x0
000504: Apr 4 04:41:06.067: //51/AF88F5808076/CCAPI/cc_api_call_digit_end:
000505: Apr 4 04:41:06.067: //51/AF88F5808076/CCAPI/cc_api_call_digit_end:
000506: Apr 4 04:41:06.739: //51/AF88F5808076/CCAPI/cc_api_call_digit_begin:
Source Call Id=51, Digit=6, DigitBeginFlags=0x0,
Rtp Timestamp=0x27FE48, Rtp Expiration=0x0
000507: Apr 4 04:41:06.739: //51/AF88F5808076/CCAPI/cc_api_call_digit_end:
Source Call Id=51, Digit=6, Duration=100,
000508: Apr 4 04:41:06.739: //51/AF88F5808076/CCAPI/cc_api_call_digit_end:
000509: Apr 4 04:41:07.379: //51/AF88F5808076/CCAPI/cc_api_call_digit_begin:
Rtp Timestamp=0x287B48, Rtp Expiration=0x0
000510: Apr 4 04:41:07.379: //51/AF88F5808076/CCAPI/cc_api_call_digit_end:
000511: Apr 4 04:41:07.379: //51/AF88F5808076/CCAPI/cc_api_call_digit_end:
000512: Apr 4 04:41:07.715: //51/AF88F5808076/CCAPI/cc_api_call_digit_begin:
Rtp Timestamp=0x28F848, Rtp Expiration=0x0
000513: Apr 4 04:41:07.715: //51/AF88F5808076/CCAPI/cc_api_call_digit_end:
000514: Apr 4 04:41:07.715: //51/AF88F5808076/CCAPI/cc_api_call_digit_end:
000515: Apr 4 04:41:08.059: //51/AF88F5808076/CCAPI/cc_api_call_digit_begin:
Rtp Timestamp=0x297548, Rtp Expiration=0x0
000516: Apr 4 04:41:08.059: //51/AF88F5808076/CCAPI/cc_api_call_digit_end:
000517: Apr 4 04:41:08.059: //51/AF88F5808076/CCAPI/cc_api_call_digit_end:
000518: Apr 4 04:41:13.059: //51/AF88F5808076/CCAPI/cc_handle_inter_digit_timer:
Generate inter-digit timeout CC_EV_CALL_DIGIT_END event
000519: Apr 4 04:41:13.059: //51/AF88F5808076/CCAPI/ccCallReportDigits:
(callID=0x33, digit_event=0x0, enable=FALSE, consume=FALSE)
000520: Apr 4 04:41:13.059: //51/AF88F5808076/CCAPI/ccCallReportDigits:
000521: Apr 4 04:41:13.059: //51/AF88F5808076/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x8ABCEA2C, callID=0x33, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
000522: Apr 4 04:41:13.059: //51/AF88F5808076/CCAPI/cc_api_call_report_digits_done:
000523: Apr 4 04:41:13.059: //51/AF88F5808076/CCAPI/cc_api_call_report_digits_done:
000524: Apr 4 04:41:13.059: //51/AF88F5808076/CCAPI/ccCallProceeding:
Progress Indication=NULL(0)
000525: Apr 4 04:41:13.063: //-1/AF88F5808076/RXRULE/regxrule_translate_exist_internal: no rule for callback-number number
000526: Apr 4 04:41:13.063: //-1/AF88F5808076/RXRULE/regxrule_profile_translate_internal: number=1310 type=unknown plan=unknown numbertype=calling
000527: Apr 4 04:41:13.063: //-1/AF88F5808076/RXRULE/regxrule_profile_match_internal: Matched with rule 15 in ruleset 1111
000528: Apr 4 04:41:13.063: //-1/AF88F5808076/RXRULE/regxrule_profile_match_internal: Matched with rule 15 in ruleset 1111
000529: Apr 4 04:41:13.063: //-1/AF88F5808076/RXRULE/sed_subst: Successful substitution; pattern=1310 matchPattern=^....$ replacePattern=XXX1612XXX replaced pattern=XXX1612XXX
000530: Apr 4 04:41:13.063: //-1/AF88F5808076/RXRULE/regxrule_subst_num_type: Match Type = none, Replace Type = none Input Type = unknown
000531: Apr 4 04:41:13.063: //-1/AF88F5808076/RXRULE/regxrule_subst_num_plan: Match Plan = none, Replace Plan = none Input Plan = unknown
000532: Apr 4 04:41:13.063: //-1/AF88F5808076/RXRULE/regxrule_profile_translate_internal: xlt_number=XXX1612XXX xlt_type=unknown xlt_plan=unknown
000533: Apr 4 04:41:13.063: //-1/AF88F5808076/RXRULE/regxrule_profile_translate_internal: number=9DESTINATION CALL type=unknown plan=unknown numbertype=called
000534: Apr 4 04:41:13.063: //-1/AF88F5808076/RXRULE/regxrule_profile_match_internal: Matched with rule 1 in ruleset 1112
000535: Apr 4 04:41:13.063: //-1/AF88F5808076/RXRULE/regxrule_profile_match_internal: Matched with rule 1 in ruleset 1112
000536: Apr 4 04:41:13.063: //-1/AF88F5808076/RXRULE/sed_subst: Successful substitution; pattern=9DESTINATION CALL matchPattern=^9 replacePattern= replaced pattern=DESTINATION CALL
000537: Apr 4 04:41:13.063: //-1/AF88F5808076/RXRULE/regxrule_subst_num_type: Match Type = none, Replace Type = none Input Type = unknown
000538: Apr 4 04:41:13.067: //-1/AF88F5808076/RXRULE/regxrule_subst_num_plan: Match Plan = none, Replace Plan = none Input Plan = unknown
000539: Apr 4 04:41:13.067: //-1/AF88F5808076/RXRULE/regxrule_profile_translate_internal: xlt_number=DESTINATION CALL xlt_type=unknown xlt_plan=unknown
000540: Apr 4 04:41:13.067: //-1/AF88F5808076/RXRULE/regxrule_profile_translate_internal: number= type=unknown plan=unknown numbertype=redirect-target
000541: Apr 4 04:41:13.067: //-1/AF88F5808076/RXRULE/regxrule_match: more digits needed; number= rule precedence=1
000542: Apr 4 04:41:13.067: //-1/AF88F5808076/RXRULE/regxrule_match: more digits needed; number= rule precedence=15
000543: Apr 4 04:41:13.067: //-1/AF88F5808076/RXRULE/regxrule_rule_match: partial match found, partial_match 15
000544: Apr 4 04:41:13.067: //-1/AF88F5808076/RXRULE/regxrule_profile_match_internal: partial match found with rule 15 ruleset 410
000545: Apr 4 04:41:13.067: //-1/AF88F5808076/RXRULE/regxrule_profile_translate_internal: partial match found
000546: Apr 4 04:41:13.067: //-1/AF88F5808076/RXRULE/regxrule_profile_translate_internal: number= type=unknown plan=unknown numbertype=redirect-called
000547: Apr 4 04:41:13.067: //-1/AF88F5808076/RXRULE/regxrule_match: more digits needed; number= rule precedence=1
000548: Apr 4 04:41:13.067: //-1/AF88F5808076/RXRULE/regxrule_match: more digits needed; number= rule precedence=15
000549: Apr 4 04:41:13.067: //-1/AF88F5808076/RXRULE/regxrule_rule_match: partial match found, partial_match 15
000550: Apr 4 04:41:13.067: //-1/AF88F5808076/RXRULE/regxrule_profile_match_internal: partial match found with rule 15 ruleset 410
000551: Apr 4 04:41:13.067: //-1/AF88F5808076/RXRULE/regxrule_profile_translate_internal: partial match found
000552: Apr 4 04:41:13.067: //51/AF88F5808076/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=1049, Params=0x8AD05F60, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
000553: Apr 4 04:41:13.067: //51/AF88F5808076/CCAPI/ccCheckClipClir:
In: Calling Number=XXX1612XXX(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
000554: Apr 4 04:41:13.067: //51/AF88F5808076/CCAPI/ccCheckClipClir:
Out: Calling Number=XXX1612XXX(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
000555: Apr 4 04:41:13.067: //51/AF88F5808076/CCAPI/ccCallSetupRequest:
Destination Pattern=9[1-9]T, Called Number=DESTINATION CALL, Digit Strip=FALSE
000556: Apr 4 04:41:13.067: //51/AF88F5808076/CCAPI/ccCallSetupRequest:
Calling Number=XXX1612XXX(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=DESTINATION CALL(TON=Unknown, NPI=Unknown),
Redirect Number=, Display Info=Luis Briones
Account Number=, Final Destination Flag=FALSE,
Guid=AF88F580-9C18-11E2-8076-ADF277C4B275, Outgoing Dial-peer=1049
000557: Apr 4 04:41:13.067: //51/AF88F5808076/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=
cisco-ani=XXX1612XXX
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=DESTINATION CALL
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
000558: Apr 4 04:41:13.067: //51/AF88F5808076/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x876EFC64, Interface Type=3, Destination=, Mode=0x0,
Call Params(Calling Number=XXX1612XXX,(Calling Name=Luis Briones)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=DESTINATION CALL(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=1049, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
000559: Apr 4 04:41:13.067: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000560: Apr 4 04:41:13.067: :cc_get_feature_vsa malloc success
000561: Apr 4 04:41:13.067: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000562: Apr 4 04:41:13.067: cc_get_feature_vsa count is 4
000563: Apr 4 04:41:13.067: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000564: Apr 4 04:41:13.067: :FEATURE_VSA attributes are: feature_name:0,feature_time:2310325528,feature_id:34
000565: Apr 4 04:41:13.067: //52/AF88F5808076/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
000566: Apr 4 04:41:13.071: //52/AF88F5808076/CCAPI/ccCallSetContext:
Context=0x8AD05F10
000567: Apr 4 04:41:13.071: //51/AF88F5808076/CCAPI/ccSaveDialpeerTag:
000568: Apr 4 04:41:13.071: //-1/AF88F5808076/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x8AF05288; count=1
000569: Apr 4 04:41:13.071: //-1/AF88F5808076/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x89298B54
000570: Apr 4 04:41:13.075: //-1/AF88F5808076/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x8AF05288; count=1
000571: Apr 4 04:41:13.075: //52/AF88F5808076/CCAPI/cc_api_call_proceeding:
Interface=0x876EFC64, Progress Indication=NULL(0)
000572: Apr 4 04:41:31.135: //52/AF88F5808076/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:DESTINATION CALL@i2next.com.mx:5060 SIP/2.0
Via: SIP/2.0/UDP 200.76.104.65:5060;branch=z9hG4bK1BA85
From: "Luis Briones" <sip:XXX1612XXX@i2next.com.mx>;tag=9941A4-6B4
To: <sip:DESTINATION CALL@i2next.com.mx>
Date: Thu, 04 Apr 2013 04:41:31 GMT
Call-ID: B692B7D6-9C1811E2-807BADF2-77C4B275@i2next.com.mx
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 2944988544-2618823138-2155261426-2009379445
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1365050491
Contact: <sip:XXX1612XXX@200.76.104.65:5060>
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 226
v=0
o=CiscoSystemsSIP-GW-UserAgent 6951 8494 IN IP4 200.76.104.65
s=SIP Call
t=0 0
m=audio 18188 RTP/AVP 0 101
c=IN IP4 200.76.104.65
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
000573: Apr 4 04:41:31.143: //52/AF88F5808076/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Giving a try
CSeq: 101 INVITE
Server: Inext (1.2.1-notls (i386/linux))
Content-Length: 0
000574: Apr 4 04:41:31.147: //52/AF88F5808076/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 407 Proxy Authentication Required
To: <sip:DESTINATION CALL@i2next.com.mx>;tag=dfa406cb245a7bd529187c8528a0918b.b093
CSeq: 101 INVITE
Proxy-Authenticate: Digest realm="i2next.com.mx", nonce="515d059a176029b0327e939ec71814ffeeef260e"
Content-Length: 0
000575: Apr 4 04:41:31.151: //52/AF88F5808076/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:DESTINATION CALL@i2next.com.mx:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
000576: Apr 4 04:41:31.151: //52/AF88F5808076/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 200.76.104.65:5060;branch=z9hG4bK1C18DB
Min-SE: 1800
CSeq: 102 INVITE
Max-Forwards: 70
Expires: 180
Proxy-Authorization: Digest username="8780033467",realm="i2next.com.mx",uri="sip:DESTINATION CALL@i2next.com.mx:5060",response="409d0019754ede6b77c366931850a9f0",nonce="515d059a176029b0327e939ec71814ffeeef260e",algorithm=md5
Content-Length: 226
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=ptime:20
000577: Apr 4 04:41:31.167: //52/AF88F5808076/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 102 INVITE
Content-Length: 0
000578: Apr 4 04:41:31.167: //52/AF88F5808076/SIP/Msg/ccsipDisplayMsg:
Received:
To: <sip:DESTINATION CALL@i2next.com.mx>;tag=dfa406cb245a7bd529187c8528a0918b.e37e
CSeq: 102 INVITE
Content-Length: 0
000579: Apr 4 04:41:31.167: //52/AF88F5808076/CCAPI/cc_api_call_disconnected:
Cause Value=47, Interface=0x876EFC64, Call Id=52
000580: Apr 4 04:41:31.167: //52/AF88F5808076/CCAPI/cc_api_call_disconnected:
Call Entry(Responsed=TRUE, Cause Value=47, Retry Count=0)
000581: Apr 4 04:41:31.167: //51/AF88F5808076/CCAPI/ccCallReleaseResources:
release reserved xcoding resource.
000582: Apr 4 04:41:31.167: //52/AF88F5808076/CCAPI/ccCallSetAAA_Accounting:
Accounting=1, Call Id=52
000583: Apr 4 04:41:31.171: //52/AF88F5808076/CCAPI/ccCallDisconnect:
Cause Value=47, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=47)
000584: Apr 4 04:41:31.171: //52/AF88F5808076/CCAPI/ccCallDisconnect:
Cause Value=47, Call Entry(Responsed=TRUE, Cause Value=47)
000585: Apr 4 04:41:31.171: //52/AF88F5808076/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x876EFC64, Tag=0x0, Call Id=52,
Call Entry(Disconnect Cause=47, Voice Class Cause Code=0, Retry Count=0)
000586: Apr 4 04:41:31.171: //-1/AF88F5808076/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x0
000587: Apr 4 04:41:31.171: //52/AF88F5808076/CCAPI/cc_api_call_disconnect_done:
Call Disconnect Event Sent
000588: Apr 4 04:41:31.171: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000589: Apr 4 04:41:31.171: :cc_free_feature_vsa freeing 89B4C510
000590: Apr 4 04:41:31.171: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000591: Apr 4 04:41:31.171: vsacount in free is 3
000592: Apr 4 04:41:31.171: //-1/AF88F5808076/RXRULE/regxrule_translate_exist_internal: no rule for callback-number number
000593: Apr 4 04:41:31.171: //-1/AF88F5808076/RXRULE/regxrule_profile_translate_internal: number=1310 type=unknown plan=unknown numbertype=calling
000594: Apr 4 04:41:31.171: //-1/AF88F5808076/RXRULE/regxrule_profile_match_internal: Matched with rule 15 in ruleset 1111
000595: Apr 4 04:41:31.171: //-1/AF88F5808076/RXRULE/regxrule_profile_match_internal: Matched with rule 15 in ruleset 1111
000596: Apr 4 04:41:31.175: //-1/AF88F5808076/RXRULE/sed_subst: Successful substitution; pattern=1310 matchPattern=^....$ replacePattern=XXX1612XXX replaced pattern=XXX1612XXX
000597: Apr 4 04:41:31.175: //-1/AF88F5808076/RXRULE/regxrule_subst_num_type: Match Type = none, Replace Type = none Input Type = unknown
000598: Apr 4 04:41:31.175: //-1/AF88F5808076/RXRULE/regxrule_subst_num_plan: Match Plan = none, Replace Plan = none Input Plan = unknown
000599: Apr 4 04:41:31.175: //-1/AF88F5808076/RXRULE/regxrule_profile_translate_internal: xlt_number=XXX1612XXX xlt_type=unknown xlt_plan=unknown
000600: Apr 4 04:41:31.175: //-1/AF88F5808076/RXRULE/regxrule_profile_translate_internal: number=9DESTINATION CALL type=unknown plan=unknown numbertype=called
000601: Apr 4 04:41:31.175: //-1/AF88F5808076/RXRULE/regxrule_profile_match_internal: Matched with rule 1 in ruleset 1112
000602: Apr 4 04:41:31.175: //-1/AF88F5808076/RXRULE/regxrule_profile_match_internal: Matched with rule 1 in ruleset 1112
000603: Apr 4 04:41:31.175: //-1/AF88F5808076/RXRULE/sed_subst: Successful substitution; pattern=9DESTINATION CALL matchPattern=^9 replacePattern= replaced pattern=DESTINATION CALL
000604: Apr 4 04:41:31.175: //-1/AF88F5808076/RXRULE/regxrule_subst_num_type: Match Type = none, Replace Type = none Input Type = unknown
000605: Apr 4 04:41:31.175: //-1/AF88F5808076/RXRULE/regxrule_subst_num_plan: Match Plan = none, Replace Plan = none Input Plan = unknown
000606: Apr 4 04:41:31.175: //-1/AF88F5808076/RXRULE/regxrule_profile_translate_internal: xlt_number=DESTINATION CALL xlt_type=unknown xlt_plan=unknown
000607: Apr 4 04:41:31.175: //-1/AF88F5808076/RXRULE/regxrule_profile_translate_internal: number= type=unknown plan=unknown numbertype=redirect-target
000608: Apr 4 04:41:31.175: //-1/AF88F5808076/RXRULE/regxrule_match: more digits needed; number= rule precedence=1
000609: Apr 4 04:41:31.175: //-1/AF88F5808076/RXRULE/regxrule_match: more digits needed; number= rule precedence=15
000610: Apr 4 04:41:31.175: //-1/AF88F5808076/RXRULE/regxrule_rule_match: partial match found, partial_match 15
000611: Apr 4 04:41:31.175: //-1/AF88F5808076/RXRULE/regxrule_profile_match_internal: partial match found with rule 15 ruleset 410
000612: Apr 4 04:41:31.175: //-1/AF88F5808076/RXRULE/regxrule_profile_translate_internal: partial match found
000613: Apr 4 04:41:31.175: //-1/AF88F5808076/RXRULE/regxrule_profile_translate_internal: number= type=unknown plan=unknown numbertype=redirect-called
000614: Apr 4 04:41:31.175: //-1/AF88F5808076/RXRULE/regxrule_match: more digits needed; number= rule precedence=1
000615: Apr 4 04:41:31.175: //-1/AF88F5808076/RXRULE/regxrule_match: more digits needed; number= rule precedence=15
000616: Apr 4 04:41:31.175: //-1/AF88F5808076/RXRULE/regxrule_rule_match: partial match found, partial_match 15
000617: Apr 4 04:41:31.175: //-1/AF88F5808076/RXRULE/regxrule_profile_match_internal: partial match found with rule 15 ruleset 410
000618: Apr 4 04:41:31.175: //-1/AF88F5808076/RXRULE/regxrule_profile_translate_internal: partial match found
000619: Apr 4 04:41:31.175: //51/AF88F5808076/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=1056, Params=0x8AD088E0, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
000620: Apr 4 04:41:31.175: //51/AF88F5808076/CCAPI/ccCheckClipClir:
000621: Apr 4 04:41:31.175: //51/AF88F5808076/CCAPI/ccCheckClipClir:
000622: Apr 4 04:41:31.175: //51/AF88F5808076/CCAPI/ccCallSetupRequest:
000623: Apr 4 04:41:31.175: //51/AF88F5808076/CCAPI/ccCallSetupRequest:
Guid=AF88F580-9C18-11E2-8076-ADF277C4B275, Outgoing Dial-peer=1056
000624: Apr 4 04:41:31.175: //51/AF88F5808076/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
000625: Apr 4 04:41:31.175: //51/AF88F5808076/CCAPI/ccIFCallSetupRequestPrivate:
Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=1056, Call Count On=FALSE,
000626: Apr 4 04:41:31.175: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000627: Apr 4 04:41:31.175: :cc_get_feature_vsa malloc success
000628: Apr 4 04:41:31.175: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000629: Apr 4 04:41:31.175: cc_get_feature_vsa count is 4
000630: Apr 4 04:41:31.175: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000631: Apr 4 04:41:31.175: :FEATURE_VSA attributes are: feature_name:0,feature_time:2310325528,feature_id:35
000632: Apr 4 04:41:31.179: //53/AF88F5808076/CCAPI/ccIFCallSetupRequestPrivate:
000633: Apr 4 04:41:31.179: //53/AF88F5808076/CCAPI/ccCallSetContext:
Context=0x8AD08890
000634: Apr 4 04:41:31.179: //51/AF88F5808076/CCAPI/ccSaveDialpeerTag:
000635: Apr 4 04:41:31.179: //-1/AF88F5808076/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x8AF05288; count=1
000636: Apr 4 04:41:31.179: //-1/AF88F5808076/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x89298B54
000637: Apr 4 04:41:31.179: //-1/AF88F5808076/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x8AF05288; count=1
000638: Apr 4 04:41:31.179: //53/AF88F5808076/CCAPI/cc_api_call_proceeding:
000639: Apr 4 04:41:31.187: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
000640: Apr 4 04:41:40.823: %FW-5-POP3_INVALID_COMMAND: Invalid POP3 command from initiator (192.168.1.10:49980): Invalid verb
000641: Apr 4 04:41:49.231: //53/AF88F5808076/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:DESTINATION CALL@nat.i2next.com.mx:5060 SIP/2.0
Via: SIP/2.0/UDP 200.76.104.65:5060;branch=z9hG4bK1D14F7
From: "Luis Briones" <sip:XXX1612XXX@i2next.com.mx>;tag=998858-2450
To: <sip:DESTINATION CALL@nat.i2next.com.mx>
Date: Thu, 04 Apr 2013 04:41:49 GMT
Call-ID: C15D2B47-9C1811E2-807DADF2-77C4B275@i2next.com.mx
Min-SE: 1800
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1365050509
Expires: 180
Content-Length: 226
04-04-2013 11:58 AM
Looks like your credentials are invalid or your providers SIP Server is broken.
-Dan
Please rate useful posts.
